TR7 Fuel Cap Options
tzorzo
Postby tzorzo » 06 Aug 2018 05:54
Has anyone explored the option of replacing existing fuel cap with Aero Style cap?
Aero Fuel Cap.jpg (4.93 KiB) Viewed 4375 times
Regards
Tony Zorzo
Re: Fuel Cap Options
Postby Beans » 06 Aug 2018 07:36
Yes, but not yet fittted, as it needs extensive modifications underneath the filler deck
https://tr7beans.blogspot.com/2012/03/adding-lightness-to-t-kreng.html
Postby Cobber » 06 Aug 2018 07:57
My car currently has a stainless steel fuel cap from an old outboard motor fuel tank! :lol:
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
tzorzo
Postby tzorzo » 06 Aug 2018 10:16
Theo,
Do you have part number at all
I assume the filler neck will have to be raised?
Regards
Tony Zorzo
Postby FI Spyder » 06 Aug 2018 14:34
First you would have determine if you have a sealed or unsealed fuel tank system. They take different fuel caps. N/A got a sealed system as part of their emissions package. Europe got unsealed. I'm under the impression that Australia might have got either/or depending. If you modified your emissions you may have gone from a sealed to unsealed inadvertently.
Postby Beans » 06 Aug 2018 20:27
tzorzo wrote:Do you have part number at all
The filler neck will be deleted together with the steel bits supporting it.
Than the remaining slightly recessed part of the rear deck needs some adapting to accommodate the holes for the filler cap mounting bolts.
These bolts also mount a connecting neck that needs to be fitted underneath the filler cap to attach the filler hose to, which is fitted between tank and filler cap.
You'll need a cap from the Aero 400 series from https://www.newton-equipment.com/index.html together with a matching connecting neck .
FI Spyder wrote:First you would have determine if you have a sealed or unsealed fuel tank system ...
That's a good call from FI Spyder. The cap shown is non vented.
This will in my case (hopefully one day) be solved by a one way valve fitted to the tanks vent pipe.
moestr7v8
Postby moestr7v8 » 06 Aug 2018 20:44
I have put one on my V8, did it a couple of years ago no problems with it and it looks really good.
I purchased mine from Rally Designs.
Moe
