Can someone tell me which bolts fit in which holes?
MikeRotherham
Postby MikeRotherham » 02 Aug 2018 21:04
Evening experts
I'm reassembling the front suspension. Could someone tell which bolts go in which holes?
Regards
Re: Can someone tell me which bolts fit in which holes?
Postby saabfast » 03 Aug 2018 12:35
Memory is a trifle vague now but I think its 3A (calliper), 1B (calliper & Steering Arm) and 2C (Steering Arm). I think you have a thick spacer washer missing which goes in 2C. No doubt someone will be along to correct me shortly!
Postby Hasbeen » 04 Aug 2018 10:04
Put everything in place, calliper, steering arm & strut, & I believe it becomes self explanatory. At least it was for me when I did it. Once things were in place it all became obvious.
REX
Postby REX » 04 Aug 2018 10:49
If you put the longest bolt in the wrong place, it will lock up the disc. Before putting the wheel back on, check everything spins freely.
Postby FI Spyder » 04 Aug 2018 14:29
As mentioned there is a thick spacer missing. Where it all goes is self explanatory as you assemble, it will only go together one way. Personally, I'd get my sandblaster out first. :P
Postby busheytrader » 04 Aug 2018 14:54
+1 for the thick washer / spacer UKC1146 for the standard brake callipers. https://rimmerbros.com/Item--i-GRID006193
MikeRotherham
Postby MikeRotherham » 08 Aug 2018 20:38
Thanks for all your replies.
There was no thick spacer washer just the three bolts and spring washers I'm assuming because the previous owner fitted upgraded calipers.
Mike.
Postby busheytrader » 09 Aug 2018 08:02
Hi Mike,
My Ford Capri / Granada callipers won't fit with the spacers, they have to be removed. I don't know about the other upgrades.
