All new front suspension
Postby stevie_a » 15 Jun 2018 07:22
All new front suspension ready for 700 mile round trip to Gaydon
Finally finished
. All new anti-roll bar bushes in poly
. Anti dive kit
. Track rod ends
. Ball joints
. Rubber gaiters
. Springs
. Gas adjustable shocks
. Brake disks
. Brake pads
. Brake Calipers ( Capri 2.8 i )
. Brake pipes
. Also all new MK2 strut top roller bearings ( designed and made by John Gibson )
Just to get tracking done ( am i correct in saying the setting is set to "0" )
Then Mot
Re: All new front suspension
Postby Beans » 15 Jun 2018 07:43
stevie_a wrote: ... Also all new MK2 strut top roller bearings ( designed and made by John Gibson )
Pictures please :mrgreen:
stevie_a wrote: ... Just to get tracking done ( am i correct in saying the setting is set to "0" )
Aim for a slight toe in
Postby stevie_a » 15 Jun 2018 11:29
Postby FI Spyder » 15 Jun 2018 15:05
Re: toe in. Zero is at one end of the specification, not sure what the other is in degrees. Always thought there should be a little.
Postby Beans » 15 Jun 2018 18:24
stevie_a wrote:Image
That looks rather familiar :mrgreen: though I machined a step in as a support for the seal ...
http://tr7beans.blogspot.com/2007/05/dhc-front-suspension-upgrade.html
Postby stevie_a » 15 Jun 2018 18:30
Ah i stand corrected then Sir , i have been misinformed :oops:
Postby Beans » 15 Jun 2018 18:35
On closer inspection of your pictures there's something that worries me, the gap between the spacer and the disc.
It looks like you have the wrong disc/spacer combination (standard Capri disc with Rimmer's spacer)?
Postby stevie_a » 15 Jun 2018 18:37
Car has not been driven as yet, how long before the front end settles down ?
looks like a 4x4 just now ... :lol:
Postby stevie_a » 15 Jun 2018 18:57
Beans wrote:On closer inspection of your pictures there's something that worries me, the gap between the spacer and the disc.
Discs and calipers are Capri 2.8i vented, i see the gap and have asked the question
Postby busheytrader » 15 Jun 2018 20:34
I've had the S & S Capri disc brake kit on my wedge since the early 90's. IIRC there's no gap between the disc and adapter on mine.
If you need a close up of the disc / adapter I'll take the wheel off for a photo
Postby stevie_a » 15 Jun 2018 20:45
This is my old set up, can't quite see
Postby Beans » 16 Jun 2018 13:32
A frontal view of my uprated Ford based front brakes as supplied by S&S
Postby stevie_a » 16 Jun 2018 14:16
This is now been rectified thanks very much beans, was a silly mistake, now been test driven and been and passed MOT.
paulheritage
Postby paulheritage » 16 Jun 2018 17:26
My car sat high when I replaced springs and turned out the ‘standard’ new springs were different height to the original standard spring. I ended up putting my old springs back on as all the new ones were the same.
Cheers Paul,
1962 TR4 2.2, CT17054 - White (on the road)
1977 TR7V8 4.0 FHC rally car, ACG 35005 - Tahiti Blue (now sold)
http://www.TR7.co.uk
sonscar
Postby sonscar » 16 Jun 2018 19:30
I can not get my head around a car "settling"when changing the springs.Surely the spring rate stays the same,or should,the rubbers may compress but that would mean they are already worn?If the car is rolled forwards enough to unload the tyres from being jacked up and the bolts tightened at ride height there should be no settling?Steve..
