Fuel gauge problem.
atc40
Fuel gauge problem.
Postby atc40 » 15 May 2018 17:51
My fuel gauge has just started to read full scale whenever the ignition is turned on.
Have checked all the obvious things, sender unit removed from tank and working okay, all wiring checked okay.
So now believe the problem is the gauge, dash is out with gauge removed and have got some resistance reading across the 3 terminals.
Does anyone have a known working gauge that they could measure the resistance across the terminals so I can compare readings?
Retired and loving it!
1982 TR7 V8 4 Litre.
1978 Stag 4.2 Litre.
XSeries
Re: Fuel gauge problem.
Postby XSeries » 19 May 2018 11:41
I have a couple of NOS gauges that I can access....
Brian
atc40
Postby atc40 » 19 May 2018 21:12
Thanks Brian, that would come in handy if not for me but maybe useful for someone in the future.
Replaced mine with an old unit I had and seems to be working okay now.
I did record the resistance of the old unit and the new unit before fitting.
Users browsing this forum: No registered users and 123 guests
