Headlights squawk when going up and down
alc59
Postby alc59 » 28 Feb 2018 16:27
It all works fine, but the noise is awful. I guess some lubrication is needed. Has anyone any experience or advice before I set out sorting this?
Thanks
Al
Ianftr8
Re: Headlights squawk when going up and down
Postby Ianftr8 » 28 Feb 2018 18:04
Turn the power off before you do anything to the headlight mechanism - I normally find that a can of spray grease will get into everything ok and stop the noises.
Ian
Ian Freeman
1979 TR8 DHC KDU 315V Poseidon Greens USA car that never crossed the pond. Kept by the factory for it's first 14 months.
Triumph Courier
Triumph owner for 40 years
From near Chelmsford in Essex, UK
Postby FI Spyder » 01 Mar 2018 15:47
While the battery is disconnected and you are in there spraying, I would hand cycle the mechanism through complete range to make sure there is no physical contact anywhere due to misalignment/loose rubber surround etc. You never know. Any assumption can lead you down the garden path.
supercass
Postby supercass » 01 Mar 2018 15:56
I know these headlights come in for a lot of criticism but with the odd spray of silicone fluid mine have never given any problems in 37 years! supercass
Postby Beans » 01 Mar 2018 19:12
As FI Spyder writes disconnect the battery before you start working in the area underneath the headlamps!
Or you might loose some fingers. Because turning the knob underneath the lift motor very slightly will otherwise actuate the motors.
And they will only stop when the headlight is fully raised :shock:
Other possibility is to disconnect the red connectors in the engine bay behind the headlamps, as per red label in the engine bay.
This has the added advantage that you can clean the connectors contacts while you're at it!
Said label is visible in the lower right corner of the picture below.
Users browsing this forum: No registered users and 344 guests
