Tunning engine
Xtmrich
Tunning engine
Postby Xtmrich » 17 Sep 2017 17:22
Hi anybody in Bristol uk who can recommend someone to come out and tune up my tr7, just fitted accuspark ignition shes running but poorly cheers Rich
Re: Tunning engine
Postby saabfast » 17 Sep 2017 19:47
Probably just needs the timing reset. When you fit the electronic stuff it shifts the trigger point compared to the points. Just get a strobe, clip the sensor to No1 lead and adjust the distributor so the pointer on the crankshaft pulley is around 10deg BTDC from memory. Worked fine on my Pertronix system.
Xtmrich
Re: Tunning engine
Postby Xtmrich » 17 Sep 2017 21:18
Ok I will give that a go tomorrow thanks for your help cheers Rich
