Replacing wiper arms - hmmmm!
nadg63
Postby nadg63 » 13 Jul 2017 07:40
My car came without any wiper arms fitted, though the linkages,motor wheel boxes etc were all present. Anyway I now have new arms, nuts, gaskets, spacers etc but all is not going sweetly :(
Have gotten the passenger side one on BUT cannot get the driver side sorted, just cannot get the chrome nut to get a bite on the wheel box spindle thread!? Without any of the gubbins on there the nut goes on just fine, but once the gasket, arm and spacer enter the equation it's not having any of it :cry: :?:
Am I missing something obvious? Are they just a pain to fit?
Any help most appreciated as this is one of the last items stopping it from finally being registered and driven.
supercass
Re: Replacing wiper arms - hmmmm!
Postby supercass » 13 Jul 2017 13:16
Try fitting it and tightening it without the arm or / and spacer, leave for a while then remove and try. Often the wheel box slips or is pushed back when you fit the scuttle trim and this will pull it close enough to fit everything. Other possibility is your gasket is too thick!
Regards, supercass
Postby dursleyman » 13 Jul 2017 14:25
I just put a new seal on mine and this is what it looked like:
TR7 wiper arm seals.JPG (58.15 KiB) Viewed 6049 times
Postby FI Spyder » 13 Jul 2017 15:09
I concur, I made new seals for mine, there isn't a lot of room to spare so thickness of the seal is critical (can't be too thick) especially to get the seal compressed that first time.
nadg63
Postby nadg63 » 14 Jul 2017 11:51
Thanks guys, I was wondering if it was due to the gasket thickness - will investigate more.
Users browsing this forum: No registered users and 1 guest
