Mystery Cable
Mystery Cable
Postby UKPhilTR7 » 02 Jul 2017 07:48
Today, I went to start up my girl and she was really rough when starting for a bit. With the choke out, she would cut out after a few seconds. Nothing would stop her cutting out at the start, choke, gas, praying, nothing. So finally, I got her started (running rough) and I looked around the engine bay while trying to feed her gas from the carb linkage. I noticed a constant spark towards the back of the block near the gearbox. The spade connector in the picture below was touching the block and sparking.
I am not sure what this cable/connector is for, but I think it may be to do with the dizzy and the old points, which is no longer being used as I have an electronic ignition. Now I have a female connector on it to stop it from touching the block until I know what it is for.
Does anyone know what this wire is for and where it goes?
Monkeyzak
Re: Mystery Cable
Postby Monkeyzak » 02 Jul 2017 08:51
I had the same issue with a couple of stray wires. Apparently mine were from the factory fitted electronic ignition. Long broken and replaced. Also not taped up and sparking.
Re: Mystery Cable
Postby saabfast » 02 Jul 2017 19:39
White/slate is the feed to the distributor. Presumably your electronic ignition has superseded it. There should also be a similar wire from the coil to the tach.
sonscar
Re: Mystery Cable
Postby sonscar » 02 Jul 2017 20:19
If it is the coil wire it goes to a multi plug on the Lhs of the gearbox tunnel if you wish to disconnect it.Beware as the oil pressure lamp wire is similar in colour whilst grovelling in the footwell.Steve..
Users browsing this forum: No registered users and 249 guests
