Brake pedal switch
pandemonium
Brake pedal switch
Postby pandemonium » 27 Jun 2017 13:37
Ive had 3 lucas brake pedal switches since Ive had my TR7, they are fitted to numerous BL cars and they are aboslute plastic rubbish! they don't last, you have no confidence in them, you are always checking you brake lights.
so today ive done a bit of internet digging, and measuring and I have sourced a much better made replacement, steel construction and the same 12mm thread so will fit straight into the bracket.
The part No is 464110010 manufactured by FAE and fits BMW cars and can be purchased from Europarts.
Re: Brake pedal switch
Postby busheytrader » 27 Jun 2017 16:55
Does the bracket require a bit of fettling / bending to set the on / off point?
pandemonium
Postby pandemonium » 27 Jun 2017 19:22
Nothing fitted and working in 30 seconds!
Postby FI Spyder » 27 Jun 2017 19:42
I replaced my defective Delco switch with a more reliable Lucas switch (OEM). Been working ever since. Always good to have alternatives though.
Postby dursleyman » 29 Jun 2017 16:58
This is the inside of a brake switch I bought off Ebay recently and which went faulty in a couple of weeks due to burning on the contacts. Don't know what the metal is but very poor quality.
Postby Cobber » 29 Jun 2017 17:05
I recognise that metal, it's called: worthless Chinese shit.......I see all too much of it these days!
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
alc59
Postby alc59 » 29 Jun 2017 20:40
I've had two replacements which were similar plastic rubbish, including some with a Lucas label.
I now have this from ebay.
BRAKE LIGHT SWITCH..... BMW MODELS FROM 1965 INC..2002..M3..M5..323I..6 & 7
Looks a lot better quality with a steel casing. Only time will tell.
pandemonium
Postby pandemonium » 30 Jun 2017 13:17
That's the one I replaced, please use the BMW part number I posted.
Postby dursleyman » 03 Jul 2017 14:56
This just arrived and looks promising. Thanks to pandemonium.
alc59
Postby alc59 » 05 Aug 2018 18:41
Further to my 2017 post, that brake light switch has now failed. Does anyone have any new suggestions?
Postby Beans » 05 Aug 2018 20:12
In almost 30 years of TR7 motoring I have only had one failure of an original brake light switch.
And after cleaning it the failed switch functioned again, and still does over 10 years on.
Though I always carry two spares with me in the car, just in case ...
Postby busheytrader » 05 Aug 2018 21:50
Well, Rimmers have switches ranging from genuine to aftermarket at £19.31 to £1.60 respectively, Mini Spares have the same part at £4.03, whilst the rest of the inter web has the same part sourced from at least half a dozen manufacturers, including Lucas, at various prices in between. It's a bit of a lottery.
My Intermoto boxed brake switch is still working Since '98 but as to where it was made, who knows?
Postby busheytrader » 05 Aug 2018 21:58
Is that a puller of some sort in the middle of your grey tool box Beans?
Postby dursleyman » 06 Aug 2018 00:54
alc59, I like the BMW one. Search for the part no. 464110010. The FAE one I got is a proper quality item and gives me confidence it will last.
Postby Beans » 06 Aug 2018 07:23
busheytrader wrote:Is that a puller of some sort in the middle of your grey tool box Beans?
Those are little tools to squeeze shut fuel lines. Handy when changing fuel filters or working on the carburettors.
