A ramp issue
Monkeyzak
A ramp issue
Postby Monkeyzak » 27 May 2017 20:13
Technically this isn't a TR7 issue but as it's stopped me working on mine it is to me.
I bought ramps after I bought the car. The sort you drive on to a plate then can jack it up further. I needed extensions as the TR7 is too low
Anyway. They slip on my garage floor. I am reluctant to bolt anything through the floor as I don't know how far down the membrane is and I've loads of issues with the floor.
How can I secure blocks to stop the ramps moving? Presumably i cant glue them?
This is stopping me working on the car so is rubbish. I'm reluctant to bin them and buy axle stands as I've spent enough. If so my Mrs tells me
atc40
Re: A ramp issue
Postby atc40 » 27 May 2017 20:28
If you mean that they slip as you try to drive onto the ramps, then cut a length of old carpet and loop it around the ramp so that the weight of the car is on the carpet as you approach the ramps. This has always worked for me.
Retired and loving it!
1982 TR7 V8 4 Litre.
1978 Stag 4.2 Litre.
Monkeyzak
Re: A ramp issue
Postby Monkeyzak » 27 May 2017 21:25
Thanks. I'll try that tomorrow
Monkeyzak
Re: A ramp issue
Postby Monkeyzak » 28 May 2017 14:17
Sorted. Thanks for the advice. I had spare foam matting tiles. Worked a treat
Re: A ramp issue
Postby FI Spyder » 28 May 2017 14:49
I always thought that would be a problem with those things so I never bought them. Any time I want to do some work on the front end where the load can be on the tires and I want to do it quick I use 2"x12" treated fir with one end up on cinder blocks with regular brick on its side half way along with a piece of 2x4 screwed on the end to prevent the car going over (to far). This gives a short length of 2x12 that isn't supported as the car rolls up and when it's at the end it is nearly over the end block. I've used this for all my cars for past 37 years for changing oil, coolant etc. As my particular driveway is pretty sloped, the car is pretty level when the car is up on the ramp. As I had the stuff lying around it cost me nothing but if bought it would be not expensive.
When in the garage (flat) and I want the car up off the ground to rotate tires or do anything non fluid related I put the car up on jack stands. As my jack is a cheap one and not low profile I first drive up on pieces of 2x12 to get the extra 1 1/2" so the jand will fit under the K support with some supporting wood for protection and help distribute the lifting force a bit. A number of years ago I did buy some combo jack stands/hydraulic lifts that in total will give up to 21" of lift so I can drop the transmission out from under the car and roll it out (when I changed the clutch). They were $36 each on sale and paid for themselves when I changed the clutch.
Users browsing this forum: No registered users and 27 guests
