New throttle linkage on eBay
Spike
Postby Spike » 30 Apr 2017 09:49
i know a number of us have done this already by buying the bits etc..., and it looks like you can get all the bits ready to go now.
http://www.ebay.co.uk/itm/352022927502? ... EBIDX%3AIT
Seems a fair price, think i paid about the same for all the bits separately.
regards
Re: New throttle linkage on eBay
Postby UKPhilTR7 » 30 Apr 2017 22:40
Looks good but I may be missing something. What is the direct benefit of these.
Spike
Postby Spike » 01 May 2017 09:55
it takes out the wear/play of the bent bit of wire/linkage and gives a nicer throttle action. I did it on mine as the throttle action was a bit stiff at light peddle pressures and it does improve things. Saying all that I'd check/replace the throttle cable first if it's a problem.
Postby UKPhilTR7 » 03 May 2017 07:26
Sorry to be a pain, but would you be able to post a picture of it in action.
Cheers, Phil
Postby Beans » 03 May 2017 08:19
UKPhilTR7 wrote:Sorry to be a pain ...
more info http://tr7beans.blogspot.nl/search/label/SU
Postby UKPhilTR7 » 03 May 2017 12:51
Now I see it, thanks :D
Howard_B
Postby Howard_B » 03 May 2017 20:37
I fitted one to mine, based on Beans suggestions & someone elses recommendations of the particular part.
It fitted first time and was a good replacement for the worn wire link, so I suggested the supplier also listed it as a TR7 replacement part for anyone else. Good to see it has been spotted.
Howard
Postby UKPhilTR7 » 04 May 2017 23:32
I enquired about buying one from them. The cost of p&p to Sydney was going to be the same as what the product was. Think that is a bit high, so currently in talks to try and bring that down a bit.
Spike
Postby Spike » 05 May 2017 09:02
If you can't get the price down have a look for 'Weber Throttle Linkage Rod 52mm'. You'll need to trim the rod down a bit but you might be able to get it local.
I think this is what I actually used on mine.
