Soft top press stud fitting tool
Postby andyf » 18 Apr 2017 14:23
I am replacing the hood press studs but don`t want to have to remove the top to use one of those hammer type of drifts, is there a pliers type of thing available that you can use? I have tried online searching but the results are not very clear whether they would work. What have others used and could you point me in the right direction?
Ta in advance.
1980 Persian Aqua DHC
simps
Re: Soft top press stud fitting tool
Postby simps » 25 May 2017 12:12
I bought a leather punch off Amazon for making a hole in my belt:
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
not sure if it would work on a hood, but at a fiver it must be worth a try???
darrellw
Postby darrellw » 25 May 2017 14:34
There is a pliers type that you can get at a fabric store, but they are often pretty weak, so I would not recommend them for a soft top. I've seen types that fit over vise grips, and there are various heavier duty types.
Here is perhaps the very best, but pricey:
http://www.sailrite.com/Pres-N-Snap-Fastener-Tool
I would avoid this type:
http://www.michaels.com/heavy-duty-snap ... 7CD006967S
This one looks sturdy and not too expensive:
http://www.iboats.com/Snap-Tool-Kit/dm/ ... oC6PDw_wcB
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
darrellw
Postby darrellw » 25 May 2017 18:41
I finally found the version that goes into your vise grips. I think this is the best option if you are only doing a few. If you where doing more, I would invest in one of the higher-end options:
https://www.amazon.com/dp/B000MQYP58?psc=1
Darrell Walker
Vancouver, WA, USA
