Fuel Hose internal diameter
MikeRotherham
Postby MikeRotherham » 11 Apr 2017 12:10
Could anyone give me the correct internal diameter of the fuel pipe on our cars?
I'm wanting to replace the fuel pipe between the main feed pipe and the fuel pump.
Rimmers are selling 1/4" diameter but I've also read 8mm mentioned elsewhere or does the slight difference not matter?
Best place to get it and avoid the poor quality stuff that is around?
Thanks
Mike.
Re: Fuel Hose internal diameter
Postby REPLIC8 » 11 Apr 2017 18:32
You need 8mm for the feed pipe to pump, and pump to fuel rail. 6mm for fuel rail to carbs. I buy it from eBay.
Postby FI Spyder » 11 Apr 2017 20:16
I get mine from local auto parts dealer. Being FI, I get high pressure hose which is pretty cheap (not the expensive direct injection hose) and if you have alcohol in your gas, make sure it's alcohol resistant.
