Circuit Diagram in AutoCad format
Howard_B
Postby Howard_B » 27 Mar 2017 13:07
A few weeks ago I realised that over the past 10 years my 7 wiring has been substantially changed by me (electronic ignition / LED lights / electric fan / driving lights etc) but the wiring diagram cannot be updated.
Because the original wiring diagram is a difficult to read, I am preparing a new version for a European standard 81 DHC as an AutoCad .dwg file. Initially I will redraw the Triumph original wiring diagram with an improved layout which will show the location in addition to the circuit. At the present rate of progress it will be a couple of months before its ready, but if anyone wants a copy for their use, please PM me.
I will issue it under an open source licence so anyone can use / modify / redistribute it so long as they allow anyone they pass it to the same rights.
Howard
j.johnson23
Re: Circuit Diagram in AutoCad format
Postby j.johnson23 » 27 Mar 2017 17:39
That would be excellent,as you say the existing drawings are a pain if like me your eyesight is not what it was. :D
Postby dursleyman » 30 Mar 2017 00:14
ooooooo, yes please can you put me down for a copy. The old eyes are not what they were!
Postby FI Spyder » 30 Mar 2017 01:10
Years ago somebody did actual colour diagrams for the different Spitfires (no more colour coding) and had them printed and laminated and sold them on line etc. for nominal amounts (I have two). Might be an untapped market for TR7's. Or if you printed (saved) them to jpg members could get them printed on 11x17 and laminated at your local Staples. Not sure if what ever program I have imports Auto Cad.
Howard_B
Postby Howard_B » 30 Mar 2017 07:06
Thats a very good idea - when I have finished I will arrange for them to be available as PDF colour copies & can provide laminated versions for a small fee.
One thing I need to check is the direction of rotation of the distributor - clockwise or anti - so that I can add it to the drawing. (I am not home to check for myself)
moestr7v8
Postby moestr7v8 » 01 Apr 2017 23:28
Add me to your list please Howard.
Moe
lgray001
Postby lgray001 » 10 Apr 2017 03:12
When done, please add me also. Could you list in .dxf format, as well?
Thanks,
Larry
MikeRotherham
Postby MikeRotherham » 10 Apr 2017 07:54
Could you add me to your list Howard please?
Howard_B
Postby Howard_B » 10 Apr 2017 12:19
DXF is not a problem so can make that available as well :)
Postby Beans » 10 Apr 2017 21:34
Wouldn't mind a copy either :wink:
Postby saabfast » 15 Apr 2017 16:59
Hi, sounds pretty useful, please add me to the list.
Thanks
Postby stevie_a » 15 Apr 2017 19:21
Yeah i'll jump on this train also.
Put me down.
Howard_B
Postby Howard_B » 16 Apr 2017 10:50
The drawing will be for the 1980 DHC UK standard with manual transmission but shouldn't be difficult to change to another version. Its taking longer than I expected but if anyone has details of the internal connections for the following it would help:-
Head Lamp Timer Unit
Main/Dip/Flash switch
Ignition switch
Howard
Postby stevie_a » 16 Apr 2017 12:57
Well that's just like getting a custom fit ... :D :D :D
smoking joe
Postby smoking joe » 16 Apr 2017 20:11
I would like to put my name on list if that's possible, any of these formats would be great, DXF, DWG or PDF.
Thanks.
SJ
Users browsing this forum: No registered users and 2 guests
