Coolant Temp Sensor in intake and filling the coolant
TimD
Postby TimD » 26 Feb 2017 19:08
I am looking for an aftermarket part number for the coolant temp sensor that threads into the intake manifold by the
water pump. My Tr 7 is carburetor model. The temp sensor is a single spade terminal, The Spade terminal has rotted off.
I am in Canada, and would like to order from my local parts distributor.
My other question is what has been found to be the best procedure for re filling the coolant system after changing the head gasket? And yes, the head bolts were an adventure! Thanks all. Tim
Re: Coolant Temp Sensor in intake and filling the coolant
Postby DNK » 26 Feb 2017 20:28
OK, I might be blowing smoke herebut...\just remove it
Take it to your local FLAPS
Match the threads
Should be pretty standard
Stick a Wedge In It
TimD
Postby TimD » 27 Feb 2017 20:46
My local part supplier sourced one, it is a TS226 by Intermotor.
Postby stevie_a » 27 Feb 2017 21:00
http://www.ebay.co.uk/itm/221908876365? ... EBIDX%3AIT
Temperature Sender / Sensor, GTR108.
High quality British made temperature thermal sender / sensor with Lucar connector and sealing washer as fitted to; Triumph TR5, TR6 TR7 and TR8, Triumph Spitfire, Triumph Stag, MG Midget and Austin Healey Sprite .
Thread; 5/8" UNF (18TPI).
Triumph TR7 temperature sensor GTR108.JPG (39.43 KiB) Viewed 3695 times
Users browsing this forum: No registered users and 292 guests
