Bloody hood !!!!
Brianc
Bloody hood !!!!
Postby Brianc » 14 Aug 2016 17:10
I had the tr7 v8 out at a shoe tpday and must not have stowed the soft top very well as when i just put it back up i noticed two small holes !!!! I can only presume i got it caught in the frame. Its a new vinyl hood this season too!!!!
Anyone got tips on how i can repair it???
I am soooooooo peed off
Brianc
Re: Bloody hood !!!!
Postby Brianc » 14 Aug 2016 17:53
I should have said that the holes are reall smallm- maybe 2mm or so.
Ive already read loads of stuff on the net about various approaches, but as per usual confusion reigns !!!
Ive left it alone tonight so i can calm down!!!!
Despite reading all the instructions about stowing the hood ive never really got it down in such a way that the hood cover will fit properly as well. - frustrating
Stag76
Postby Stag76 » 15 Aug 2016 10:45
Postby stevie_a » 15 Aug 2016 18:42
It all depends on where it is, because they are so small, i would try heating them with a hair drier till soft, press the edges to make hole smaller , then use a small drip ( tiny bit )of epoxy glue ( like araldite ) just to fill hole.
but we would need to see it first
supercass
Postby supercass » 15 Aug 2016 20:21
A vinyl repair kit should work. Not that easy to achieve a professional finish so for about £30 you may be able to get an expert to come and repair it. supercass
supercass
Postby supercass » 15 Aug 2016 20:23
PS. If the holes are symmetrical it might be possible to glue and sew a coupe of patches in and make them look like they were always there! supercass
Stag76
Postby Stag76 » 15 Aug 2016 21:30
Vinyl can be welded (by professionals) and you won't be able to see where the cut was.
Postby Hasbeen » 16 Aug 2016 02:53
Whatever you do, make sure you don't form a hard spot in the hood. If you do the flexing will all be localised & the repair edge will crack sooner or later.
My son poked 2 holes with the frame, in a near new mohair hood, folding it badly, before reading the instructions. We took it to a good trimmer who sewed patches on the inside. They are now getting tired, but it is 12 years later.
If a vinyl hood, I'd try some of the adhesive used to repair swimming pool liners, & a small piece of vinyl, on the inside. That stuff has to handle full sun, & remain flexible for years.
Brianc
Postby Brianc » 16 Aug 2016 15:00
Anyone know if a vinyl repairer in the nw of the uk?
Postby FI Spyder » 16 Aug 2016 15:35
I don't know how that would happen unless like you say it inadvertently got caught in the frame some where. My original hood 36 years old still looks like new including clear vinyl windows although I think it has shrunk a bit and is a bit stiffer. I don't know how it would hold up (probably depending on it's position and stresses at that position) but for worn spots in the vinyl floor and back covering in the trunk I used a vinyl repair kit. Also used the kit on the Tercel door cards were there was a split. It comes in various colours and you mix it to get the other colours. I matched the tan of the Tercel fine but the TR7 was easier (straight black :P ). I don't think they cost much (I bought it many years ago). You just apply it then cure it with a iron (or heat gun) that heats the included metal stamping tool. The professionals have an electric heated tool.
