Fuel Gas Petrol Filler Cap Gaskets (dhc later fhc)
Too many people duplicate work that others already have done ... if you're having something remade then tell us about it! Success and Disasters, they are all useful to know about!
XSeries
Postby XSeries » 09 May 2016 21:36
This was something I had remade last year as I was not happy with the dried hard, crusty foam on my own filler caps. Also the gasket on the top of the cap needed replacing to make sure there is a good seal (MoT failure in the UK if it is inadequate). PM me if interested - if ordering alloy wheel centres by post then these could be enclosed with no additional postage cost.
Old fuel cap gaskets
Fuel cap.jpg (167.23 KiB) Viewed 16767 times
Re: Fuel Gas Petrol Filler Cap Gaskets
Postby Maxwell » 09 May 2016 22:43
Well worth buying - fitted perfectly!
Maxwell :D
3.5 TR7 DHC \ Current :D 8)
2.0 Mazda MX5 Sport
John_C
Postby John_C » 10 May 2016 08:50
I think we need to make it clear that these components are for the later type/small filler cap and not the pre-1978 model large filler cap.
www.triumphdvd.co.uk
gr8
Postby gr8 » 10 May 2016 10:11
I concur with Maxwell.
The sponge and rubber fitted perfectly and it was a really nice job to do - start off with an old fuel cap and end up with one looking like new!
My only tip is to watch out for flying parts when you release the pin to disassemble the cap.
XSeries
Re: Fuel Gas Petrol Filler Cap Gaskets (dhc later fhc)
Postby XSeries » 12 Aug 2017 09:23
John C - the ones for the larger cap are now available as I have had some made (as you are aware since you now have a pair!). See other posting in this section.
Postby dursleyman » 12 Aug 2017 16:21
pm sent
XSeries
Postby XSeries » 17 Aug 2017 09:02
I have tried to reply via pm twice now - both stuck in outbox (have contacted administrator)!
Yes £5.75 including postage is the answer.
Postby saabfast » 17 Aug 2017 12:33
If a PM is in the outbox it just means it has not yet been read.
Postby dursleyman » 17 Aug 2017 12:47
Yes that was my fault because I hadn't read it.
Reply now sent.
Brianc
Postby Brianc » 17 Aug 2017 21:42
Im after this kit as well. - i did try and send a pm
Temporarily i have bought a locking cap frpm steve at s&s but i would like to go back original.
How does the cap vent?? I found mine wasnt venting resulting in fuel starvation.
Postby FI Spyder » 18 Aug 2017 16:19
I have both of these (venting and none venting). The venting type (UK) does so by holes in the cap mechanism (if I remember right, I have pictures of both to show the difference but can't show them at the moment). The non venting (N/A) is part of the sealed N/A system to prevent gas fumes entering the atmosphere. It vents through the emissions/fuel separator system which is why people who remove emissions can develop vacuum lock if not done correctly.
Polly-Red7
Postby Polly-Red7 » 30 Oct 2017 11:33
I've tried sending a pm but it seems to be stuck in my outbox?
I'd like to purchase two sets of seals for the later small type fuel cap. Could you please let me have details on payment etc?
Chris
Chris
1982 FHC "Polly"
Remember a TR7 is for life, not just Christmas :D :roll:
Postby dursleyman » 30 Oct 2017 13:19
Chris, don't worry it will sit in your outbox until is is opened at the other end.
Polly-Red7
Postby Polly-Red7 » 30 Oct 2017 17:03
Ok cheers dursleyman thanks for the heads up
Chris
1982 FHC "Polly"
gr8
Postby gr8 » 13 Jan 2018 23:16
PLEASE may I buy another 2 sets from you?
1 for my spare cap in case leave 1 at the petrol station again and 1 more in case you produce no more as I have been told this is the last batch you are having made??....
If you send me a PayPal invoice I will get money to you immediately.
Thank you!
SEE
