Hockey stick removal ?
toneinblack
Postby toneinblack » 22 May 2015 12:13
Whilst sorting my cruise/indicator lights out ,I thought I'd replace the broken drivers side plastic hockey stick,How do you remove the plastic lugs?
I thought it would be a simple case of just levering them out or squeezing the back of them and popping them through but there seems to be a metal pin in the middle, also once out are they reuseable?
many thanks experts :)
Steve @ SandS
Re: Hockey stick removal ?
Postby Steve @ SandS » 22 May 2015 13:05
Tap the pin through with a small punch.If you are careful and save the pin and clip you can reuse them but new ones are only a few pence.
Steve @ S&S Preparations
www.ss-preparations.co.uk
toneinblack
Postby toneinblack » 22 May 2015 16:16
Thanks Steve , will give it a try. Can imagine it's a bit tight to get at them.
Users browsing this forum: No registered users and 0 guests
