Polly gets a new home!
Polly-Red8
Postby Polly-Red8 » 20 May 2015 17:11
A good day in the Barker household as Polly finally gets a home of her own out of the elements. Now the fun begins starting with the fuel tank :shock:
Re: Polly gets a new home!
Postby Hasbeen » 21 May 2015 03:00
High there. I don.t think we've met before, so welcome.
It is nice to get somewhere to keep your car out of the weather isn't ity, but I see you are already crowding the poor car out of it's space, as we all tend to do.
However I have some bad news about that tank removal. Unless you have a side door along side the tank part of the car, you may have trouble getting the tank out there, in the normal way, unless the space beside the car is greater than it looks.
The tank slides out the opposite side of the car to the filler, & requires about 1/2 the width of the tank beside the car to do this.
If you can park it hard against the wall on the right side you should manage. I see the doors are off, is it still movable to get it across a bit.
Postby FI Spyder » 21 May 2015 15:24
Mine was removed/replaced from the back so you would want the back of the car facing the doors so you would have room. I'd get claustrophobic in there but I guess you get used to what you got (I need a six car garage). :D
Postby busheytrader » 21 May 2015 15:32
Me too for removing the tank from the rear. Drop the rear axle, remove the exhaust- simples - actually it wasn't simple but really fiddly. Apply plenty of penetrating on the tank strap nuts /studs before trying to undo them.
Good luck,
Polly-Red7
Postby Polly-Red7 » 22 May 2015 18:00
Hasbeen I've been around a while and you have helped me in the past too, I used to have the user name lbdr_barker but when moving to the new forum I decided to change to a name something more relevant to all things TR7, but thank you for the welcome none the less!
Regarding the garage it is quite wide and I have about half a tank width at that side, but I intend as suggested to turn the car around so I have more room and light before battle commences! The doors you see are replacement ones and must rank as the bargain of the century! Purchased last autumn from eBay for a total of £25!!!!! They are virtually rust free examples with no filler sourced from the USA by the seller who imported them for his project that ultimately never got off the ground.
Chris
Chris
1982 FHC "Polly"
Remember a TR7 is for life, not just Christmas :D :roll:
Polly-Red7
Postby Polly-Red7 » 26 May 2015 14:25
And so it begins..........the car is up, a liberal dosing of WD40 applied let the fun commence!
Chris
1982 FHC "Polly"
Polly-Red7
Postby Polly-Red7 » 31 May 2015 09:58
Well that was relatively painless! The old tank came out easier than I thought. The new tank is in situ with just one final strap bolt to get in, happy days !! :D :lol: Thanks must also go to Mark Cox (coxy) whoes invaluable help yesterday made life so much easier, cheers buddy!
Chris
1982 FHC "Polly"
Postby silverseven » 01 Jun 2015 02:56
props !!! (since there's no "like" button here lol)
Postby FI Spyder » 01 Jun 2015 15:41
There you go. I found taking out the tank was easy. Getting it back in was a little tricky. First one side up in first then tried the other side in first. It eventually went in. Can't remember for sure now but might have had rubber filler neck attached. Riddled it out any ways.
Users browsing this forum: No registered users and 318 guests
