Front shock absorber boots.
supercass
Postby supercass » 06 Mar 2015 16:11
Has anyone found a suitable alternative heavy duty or OEM boot for this application? My original nearside one has finally split after 33 years!! I have heard so many stories about the direct replacement variants splitting after a couple of years light use I am reluctant to purchase. Regards, supercass
Postby Workshop Help » 06 Mar 2015 16:52
Yes, please view my article in The Workshop Manual.
Postby busheytrader » 06 Mar 2015 17:04
I have the same problem with the lower ball joint boots on the track control arms. The originals lasted for years. I've had some replacements split Inside a year.
I've had advice to coat them with red rubber grease which I've tried. Hopefully they'll last longer. You'd need a lot for the front shock absorber boots!
supercass
Postby supercass » 06 Mar 2015 17:25
Wintergreen oil is supposed to be good, but I'm not sure how much it will help. The problem is as I understand the amount of filler that is used in the imported rubber product to keep the cost down. No amount of rubber grease, wintergreen or any other remedy is going to change that! As rubber boots go they are not markedly cheap so I resent paying the price for an inferior product that from the evidence I have seen is not fit for purpose. Thanks for your reply Mildred, I need to have a closer look at how your application fits. Replacement bump stops are available in polyurethane it is a shame the boots aren't. supercass
toneinblack
Postby toneinblack » 07 Mar 2015 13:08
Replaced one of mine a week or so ago and got the other side to do,
Bought them from rimmers, is there an easy way to get them to slide over where they are supposed to go ( top and bottom ) before fitting the plastic tie ?
Postby FI Spyder » 07 Mar 2015 13:25
I've used VB's rubber boots, they're going on 8 years now. While I use red rubber grease on O rings/seals for that initial lubrication (kind of like assembley lube for an engine overhaul) for things like boots I soak/lather on Maguiar's Vinyl & Rubber Restorer let them sit for 24 hours or so and then wipe them dry..
I pull mine over with a spring hook (I've got several of different sizes with my original IBM tool kit but you should be able to find them at many tool places.
toneinblack
Postby toneinblack » 07 Mar 2015 15:02
we used a large flat screwdriver to slide between the rubber and the metal and then levered it and tugged it . thought there may have been an easier way :) cheers for the tip with the hook tho.
Postby Hasbeen » 07 Mar 2015 22:49
About 5/6 years ago I had to fit new bump stops. I discovered one of my gaiters was split almost from top to bottom, & the other a large similar tear. Strangely the rest of them was quite sound, & not weak, or falling apart.
New gaiters were not available anywhere in Oz, so after ordering new ones, & temporally repaired mine. I cleaned them with degreaser followed by ether, which I just happened to have. Then glued them together with a Bostik urethane sealant similar to Sikaflex, with a half inch overlap, stapled to hold while curing. The staples were removed after curing.
After 2 days curing I refitted them, hoping they would hold until new ones arrived. They are still there, & still together. We used the new ones on the 8 when it needed bump stops, & it's gaiters were a bit past it.
I have since found there is a unit from another car, I think Holden, which fits, & has the bump stop moulded in as part of the thing. I will use them when mine finally expire.
Postby Workshop Help » 08 Mar 2015 00:39
Gentle and Heroic Souls here about. The Gabriel Part #143061 Suspension Strut Bumper is nearly identical to Part #141551 and fits the 1996-2001 FORD Escort. Either will fit our Triumph front struts just fine.
Thought you boys might like to know.
Postby Hasbeen » 08 Mar 2015 00:42
Thanks Mildred
Hasbneen
Users browsing this forum: No registered users and 318 guests
