Can anyone give any suggestions here
Postby UKPhilTR7 » 23 Feb 2015 00:11
I have purchased the items below in the picture to help protect my doors, when I finally get them to for correct. Can anyone tell me how I fit them?
I see where the corner protectors go, but there is no hole in the door to secure them to. So they just appear to sit there and when driving along, I could see them flying off. There is a hole in the protector, so it must for somewhere. I hope that I do not have to drill a hole in the door frame and use a rivet to fit them.
Also the door stops (on the edge of the picture) have bits (nipples) that fit in holes already in the door, but they do not stick. Would I be right in thinking that I will have to glue them to the door to make them stick?
whitenviro
Postby whitenviro » 23 Feb 2015 03:36
The corner protectors were held in place by a rivet, so you probably have to drill out the old one and install a new one. The bumper glues in. Use a glue that stays flexible like trim cement NOT superglue.
[/img]
Postby UKPhilTR7 » 23 Feb 2015 06:26
Thanks for that, I thought that may be the case for the door stops.I have had a look and there is no previous hole, should there be one? I am wondering mow it it has been filled in by the previous owner of the door and I had it painted over. Hopefully, i should be able to find evidence of the hole from the back.
darrellw
Postby darrellw » 23 Feb 2015 12:34
On my car, the corner protectors were held with a push-in clip, not an actual rivet. Even with held by the clip, they tend to get knocked off easily (of the corner). So I used a little trim adhesive to make them stay. If you do that, I don't think you really need the clip.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby jclay (RIP 2018) » 23 Feb 2015 15:13
Not all of the cars had the "door stop" piece, so some doors where not drilled.
Vegas_M
Postby Vegas_M » 23 Feb 2015 15:22
Hardtop vehicles did not have the corner trim, only convertibles - and not all of them either.
M.
Postby DNK » 23 Feb 2015 18:52
Darrell, post picks of said clip...
New to me
Stick a Wedge In It
Postby UKPhilTR7 » 23 Feb 2015 19:53
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Vegas_M</i>
M.
That would answer it then, as mine is a fhc. I didn't realise that when ordering them, but if I can stick them on with spray adhesive without drilling that will be my favoured option.
Postby FI Spyder » 23 Feb 2015 19:56
It's one of those plastic push pins. Good idea about trim adhesive to hold corner piece in place as it is very vulnerable (why it's there) but I would not rely on that alone.
Postby nick » 24 Feb 2015 00:05
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by UKPhilTR7</i>
I'd be happy to take those corner protectors off your hands for my DHC. PM me if you would like to sell them.
'79 TR7 DHC
'76 TR7 FHC
Dave Dyer
Postby Dave Dyer » 25 Feb 2015 19:42
I have a 1980 FHC (UK car) and it has the door corner protectors.
Its a Premium limited edition, I don't know if that makes a difference. I need Chris Turner to come along and confirm or not. Or whether its a model year thing.
Dave
Postby saabfast » 26 Feb 2015 12:42
As far as I was aware the DHC had the protectors to stop injury from the sharp corner of the door (good old H&S?) whereas in the FHC the corner was protected by the window frame from easy contact and injury.
As above, mine have the plastic rivet but tended to catch and get turned back into the door edge so are now glued as well.
Users browsing this forum: No registered users and 345 guests
