Alloy wheels
gavinj4
Alloy wheels
Postby gavinj4 » 22 Feb 2015 19:21
Hi, does anyone know if Triumph Stag alloys will fit the Tr7. There's quite a few cheap on flyaway at present.
Gavin
Postby stevie_a » 22 Feb 2015 20:18
<font color="teal"><b>I would say no
PCD
Stag 4x114.3
TR7 4x95.25</b></font id="teal">
Image ImageImageImagehttp://www.smallbiztranscripts.co.uk
j.johnson23
Postby j.johnson23 » 25 Feb 2015 04:46
They will not fit,different stud PCD.
Postby john 215 » 25 Feb 2015 05:22
Hi Gavin,
Plenty of MGF wheels out there, and as you know they fit ok but use the matching nuts. Get yourself up to Stoneliegh this weekend, there were loads of MGF / TF's there last year and look at your options.
I took these pictures last year of some of the possibility's -
birminghamtr7
Postby birminghamtr7 » 25 Feb 2015 08:15
i had a set on one of mine years ago did use an adaptor or spacer plate though
Postby UKPhilTR7 » 25 Feb 2015 09:43
I must admit most of these look great and I would love to have these on my car. I am looking on fleabay at the minute and they looks like they are going for around a ton, so not too bad :)
gavinj4
Postby gavinj4 » 26 Feb 2015 17:27
Thanks everyone for your thoughts. I want some alloys that will look sort of period, but not over the top. That's why I was looking at the Stag wheels. I still rt of like the Mg wheels similar to minimlises.
Gavin
Postby stevie_a » 26 Feb 2015 19:27
look here for mgf
http://www.mgf.ultimatemg.com/group2/su ... he_mgf.htm
Postby FI Spyder » 26 Feb 2015 20:16
Not a fan of new style alloys (although the black ones aren't too bad) just like I don't like the new style techno dashes but prefer the dashes of the early 90's. I like original alloys best or my early 90's era Integra alloys (I got off a California Ingtegra). Guess I'm just a 90's, 80's, 70's kind of guy.
To show you what I mean by the Integra alloy design. I've seen these on a none Accura with different (non Accura) centres
Postby john 215 » 28 Feb 2015 05:33
Hi Gavin,
There was a thread started by my learned friend Gaz a while back on alloy wheels -
http://www.forum.triumphtr7.com/topic.a ... Terms=avez
Still love my Revolutions and very period [8D]
Postby stevie_a » 28 Feb 2015 05:59
<font color="teal"><b>I forgot about that thread, that was a good informative thread. [:)]</b></font id="teal">
gavinj4
Postby gavinj4 » 28 Feb 2015 06:45
I'm liking the deeper dish look, like the banded steelies, and the competitive 5 spokes. I think they suit to period, especially if staying with 13-14" rims. I also like the look of the original alloys with the polished rim. Being a tight ar53d northerner, I don't want to spend too much. Thanks again.
Gavin
frankman
Postby frankman » 02 Mar 2015 12:43
Hi gavinj4
Yes you could use them it is the same PCD 4x3 3/4", or 4x95.25 in metric.
But the Offset is about 35mm so you lose 10 mm .. I would not go for these .. MGF are good about same Offset like TR7: 1 " = 25mm : the smaller the offset, rims come out the more (wider track) so look for the MG -- there are some Caterham with Offset 0 but these will not fit under the Fender ..
But remember, if the rim is wider at the same offset is wider on both sides
PCD 4x3 3/4", or 4x95.25 in metric MG, F, Maestro Montego, Mini Metro, Dolomite, TR7, Spitfire (but thinner Studs) Lotus Elise S1, Caterham older (newer are 108mm= Ford)
You can use something like these:
http://www.willtheyfit.com
Hello from Switzerland
Frank
Users browsing this forum: No registered users and 221 guests
