Ignition light
Troy ODoherty
Ignition light
Postby Troy ODoherty » 30 Dec 2014 23:41
The ignition light in the DHC has decided to stay on after I turn the car off, It goes out as soon as I start the engine. Any ideas ?
Cheers Troy
scotty
Postby scotty » 31 Dec 2014 03:36
Hi Troy.
There are others on the forum that are no doubt better qualified that I am to answer this but try pulling the plug off the back of the alternator. If the charge light goes out I'd say you have a leaky diode in the regulator. If it doesn't go out, I'd possibly be looking at the printed circuit on the back of the binnacle for any melted insulation.
Please let us know what you find.
Scott.
Scotty, South Australia.
1978 TR7 2.0 LT77
1981 XJS
Troy ODoherty
Postby Troy ODoherty » 01 Jan 2015 09:47
Thanks Scotty I in plugged the alternator today and the light went out. I will rebuild one of the spares and swap it. Thanks for the advise.
Cheers Troy
Troy ODoherty
Postby Troy ODoherty » 14 Jan 2015 07:03
I changed the alternator for a new 65 amp version today. All fixed. Brand new from Australian supplier $200. Slight modification by rotating front housing and drilled out one hole and it bolts straight up. [:D]
Cheers Troy
scotty
Postby scotty » 16 Jan 2015 06:00
Good stuff. Glad to hear it was reasonably straightforward Troy.
What alternator did you use, a Lucas or alternative?
Scott.
1978 TR7 2.0 LT77
1981 XJS
Troy ODoherty
Postby Troy ODoherty » 16 Jan 2015 09:42
Hi Scotty. Lucas hi output. I know oxymoron. Supplier from EBay Aus on the sunshine Coast. Thanks for your help.
Cheers Troy
Users browsing this forum: No registered users and 304 guests
