Doors
Doors
Postby dursleyman » 01 Dec 2014 10:25
Saving the good bits off my old car I came across a couple of surprises in the doors.
First anyone seen this block of polystyrene before, it seems to be there to stop the window dropping too far?
Second, I often had a rattle from the window, this could be why. I found the felt runner in the bottom of both doors.
1981 TR7 Sprint DHC
Postby FI Spyder » 01 Dec 2014 13:16
The runners were just friction fit. Both mine were in the bottom as well. I glued in the new ones.
supercass
Postby supercass » 01 Dec 2014 14:45
Never seen white polystyrene in the door bottom before. Wonder if it was placed there at some stage to "hold in" filler whilst it dried?
supercass.
Postby dursleyman » 01 Dec 2014 16:17
I first thought it was to hold filler then realised it was exactly the same in both doors and appears to be some kind of stop to limit the window dropping.
1981 TR7 Sprint DHC
whitenviro
Postby whitenviro » 01 Dec 2014 21:02
I've been inside both my doors more times than I want to count; neither have the styrofoam block. But have had plenty of trouble with the felts sliding out of the tracks. Finally used silicone to glue them in place.
[/img]
Postby silverseven » 02 Dec 2014 00:39
Actually had to pop my felts in a few months back once again ...never seen that block though
parrish
Postby parrish » 02 Dec 2014 14:08
Their are two diff weren't size window felts available, and one does slide out very easily, the larger of the two available from Rimmers is a nice snug tight fit and I can't imagine it slipping at all.
I replaced mine a year ago and had one of each size sent (accidently) yes the smaller felt works but is far too loose.
1983 Del lines TR8. FIAT 131 Abarth Replica.1977 FIAT 131 1600 TC, 1996 2013 Fiat 500, 2012 Ford Fusion.
Postby dursleyman » 11 Apr 2015 16:15
Update: Just been battling to put a new window winder mechanism in the TR7 and remember now why I hate doors - because I always find them an absolute swine to do any work in, like the winders or felts etc. There is never quite enough space or there is something in the way.
Anyway, the reason for this update is I think I have found why there was a polystyrene block in the bottom of the doors on my old red TR7. I battled with the new winder gratefully following the very helpful guide by MikeRotherham in the Workshop Manual.
http://www.forum.triumphtr7.com/topic.a ... C_ID=20318
All went as well as expected and it went up and down fine but then the white roller that runs in the door guide came out of its track. This seems to have been because the window came down too low and the roller came out of the end.
Enter the polystyrene block in the bottom of the door and all is now perfect. The glass stops on the block before the white roller comes out. Not sure why it is necessary, maybe something is wrong or the winder mechanism is slightly different but its doing the job nicely.
1981 TR7 Sprint DHC
Users browsing this forum: No registered users and 249 guests
