MGF front disc
Reddragon
MGF front disc
Postby Reddragon » 09 Nov 2014 10:55
All The other day I saw in Rimmer's ad that they had vented / slotted front discs for sale from the MGF. Has any one in the UK looked into whether these disc would fit the TR7 and what it would take to adapt them? Would the MGF caliper fit the Tr7?
Thank you,
Dale
1974 TR6
1977 TR7 FHC
Postby john 215 » 09 Nov 2014 11:34
Hi Dale,
Not really looked into this one myself but the MGF disc fits on top of the hub, located by a countersunk screw where as on ' ours ' the disc goes behind the hub with threaded holes to attach the hub, not saying it cant be done though. I did look at using them on the rear of my DHC but Maestro discs were cheaper ! Plus being Metro based on the MGF the hub would be smaller.
One thing myself Mr Wood and myself were looking at set of MGF Trophy front caliper's at Stoneliegh Resto Show and looking at the possible use on ' our ' car's ??? Naturally mill of the MG logo [^] Made out alloy and 4 pot may have possibility's. May have a play over the winter.
Postby Chris Turner » 09 Nov 2014 12:22
I have had a pair of MGRV8 calipers for abot 15 years, never measured them but perhaps they could fit.
www.triumphtrs.co.uk
THE Coca Cola car
TR7 Sprint SJW 539S
Reddragon
Postby Reddragon » 09 Nov 2014 19:53
John - Chris
Any up dates on this subject would be appreciated. I am still a ways from putting brakes on this project. If I can find available parts, such as the MGF, that would replace the stock weak brakes then taht would be a plus.
Thank you for your replies and stay in touch.
Dale
1974 TR6
1977 TR7 FHC
Postby jclay (RIP 2018) » 09 Nov 2014 21:15
Front:
http://www.jclay.me/jclay/Big_Brakes.html
http://www.jclay.me/jclay/Big_Brakes_2.html
Rear:
http://www.triumphtechnical.me/triumphtechnical/Rear_Disk_Brakes.html
Bill Sales
Postby Bill Sales » 10 Nov 2014 03:12
I have fitted a set of MG TF160 Callipers and 305mm discs to my 7
Had to drill out the thread in the struts as the calliper of the MG has thread.
MG has 16" wheel so had to dress the callipers slightly to clear the 15" wheels on my car.
Cleaned up centre bore of disc to fit on hub and drilled 4 holes to bolt on to hub.
The rears complete with MG master and booster will do in this December.
Image[/URL]
Bill Sales
Postby john 215 » 10 Nov 2014 05:13
Hi Bill,
Nice job mate, looks like mine and Mr Wood's suspicion was right they will fit ( can be made to fit should I say ) and inside 15 inch wheels, I am sure a standard Trophy were 16 inch. The ' bell ' on the MGF disc does not look as deep as the TR7's ? no clearance issue with the tyre and strut [?]
Bill Sales
Postby Bill Sales » 10 Nov 2014 06:29
Callipers fitted to the outside of strut mounting and align perfectly with the MG disc. Used crimp lock nuts with high grade bolts to fit discs.
Bill Sales
John Wood
Postby John Wood » 10 Nov 2014 10:02
The modern conversion? Princess 4-pots are hard to find nowadays.
TR7 Sprint & TR8
Stag76
Postby Stag76 » 10 Nov 2014 18:48
A conversion used in Australia incorporates a Subaru Disc and Holden Caliper.
See this post by Rodney Wells:-
http://www.forum.triumphtr7.com/topic.a ... dney,wells
TR7 Convertible
Sprint Motor
MegaSquirt EFI
lancsman
Postby lancsman » 10 Nov 2014 20:36
Continuing with the MGF brake parts possibilities a supplier in Cheshire has developed a 280mm brake disc kit for MGF's which may be of interest for TR7 or TR8 conversion.
The enlarged discs are well thought of by MGF owners who have converted and they may be of a size more suitable for TR7/8.
They seem to be well priced too.
I have no connection with the supplier by the way, he's Cheshire and I'm Lancashire.
Link.....
http://www.mgfmania.com/
Lancsman
paulheritage
Postby paulheritage » 11 Nov 2014 21:55
According to the EBC catalogue the MG F Trophy disks are 24/22 thickness, 304mm diameter, and 39mm height. That compares to 57mm height TR7 disk.
I personally found it easier to go Hi-Spec front setup.
Cheers Paul,
1977 TR7V8 4.0 FHC rally car, ACG 35005 - Tahiti Blue (on the road)
1976 TR7 2.0 FHC, ACG 3115 - Java Green (now sold)
www.TR7.co.uk
Postby john 215 » 12 Nov 2014 04:47
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><font size="3"><font color="red">I personally found it easier to go Hi-Spec front setup.</font id="red"></font id="size3"><hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Ahh but where is the fun in that [;)] If I had to do my DHC again would have brought a set of those but at the time they were not available
There is no way MGF set up will fit inside my wheel's so not at the moment but if I ever come across a cheap pair may have a ' play '
Users browsing this forum: No registered users and 314 guests
