Clutch Fork bearing question
Stevie P
Postby Stevie P » 08 Nov 2014 10:17
Hi guys
On the Release / Throwout Bearing, what stops the carrier spinning on the Gearbox nose?
http://www.rimmerbros.co.uk/Item--i-FRC5369A
Looking at this picture, I can't figure out what stops it spinning and falling off the fork pins!
Your thoughts please.
Thanks,
Postby busheytrader » 08 Nov 2014 10:35
Each fork pin fits into a slipper pad which engages into the carrier. Rimmer's is good for exploded diagrams
http://www.rimmerbros.co.uk/Item--i-GRID006092
http://www.rimmerbros.co.uk/Item--i-159003A
Hopre this helps
Postby dursleyman » 08 Nov 2014 11:34
Steve, there are a couple of flats where those slipper pins locate it onto the fork.
Postby busheytrader » 08 Nov 2014 20:05
When I last replaced my clutch components the slipper pads had very sharp edges. The bearing carrier looked like it was made of glass filled nylon unlike the original metal item.
I filed down the sharp edges and corners of the slipper pads to prevent them gouging lumps out of the carrier
Users browsing this forum: No registered users and 205 guests
