heavy Duty clutch release arm
Postby dursleyman » 14 Oct 2014 10:03
Just noticed Rimmers are selling a heady duty clutch release arm and a kit for the Land Rover which might be OK for our cars. Anyone else seen these or tired one? They are listed as a Britpart product and their site lists them for Defenders, Discovery and Range Rover Classic.
1981 TR7 Sprint DHC
Postby Cobber » 14 Oct 2014 11:05
Looks like a standard arm with a strip of flat bar welded across the back of the pivot socket. That would be easy enough to do to a standard arm.
'98 MG-F, 69'Ford F250.
Postby dursleyman » 14 Oct 2014 16:13
Agreed that is exactly what it looks like but the other bits look interesting as well. Those nicely shaped slipper blocks would be much easier than trying to get our square ones onto the release bearing.
Also interesting that they market them to the Land Rover lot but not the TR7/8 (yet).
Postby busheytrader » 18 Oct 2014 07:53
The welded on strap is a great idea. But won't the fulcrum pin still wear out the socket in the arm?
Instead of the pin punching its way through the arm, it'll wear through to the strap. IMHO, the clutch arm won't fail dramatically like the original (which happened to me) but will still need to be swapped out when the action gets rough. What do you reckon?
Postby Odd » 18 Oct 2014 09:39
My view as well - it will fail, but you'll be able to limp home.
Sort of like the injection, it will get you home in limp home mode
but you'll hate the fuel consumption...
Postby FI Spyder » 18 Oct 2014 13:25
By the time it wears through the strap it will be 2099 and the car will have 550,000 miles on it. Mine has 104,000 miles when I did the clutch two years ago and it only had a little wear.
Postby busheytrader » 18 Oct 2014 15:48
The fulcrum pin wore through mine in less than 60,000 miles when it was a daily driver. It had worked all its life in London's suburbia so the clutch was probably worked harder than most.
Users browsing this forum: No registered users and 103 guests
