Today, I did one of them jobs, that has been on my list for a long time. Not a particularly hard job, just never got around to doing it before now.
I put the net washers on my headlight rubber surrounds and then put both of them on my girl. All was going good until I tested the lights. The one issues I have had for a long time, just think it would be a good time to sort it out now. The other issue is new, after putting the rubber surrounds on:
<b>Issue 1:</b>
The motors are out of sync, but the passenger light comes up all the time. The drivers side only comes up now and then. If I pray to the TR7 headlight god or a black cat walks in front of my car, the drivers side light will come up and go down. I was thinking a bad earth, but would that result in the light not coming on too? The light does come on even if the pod does or does not go up. Any suggestions guys on how to get the pod to always come up?
<b>Issues 2:</b>
Now with the rubber surrounds on the passenger side (the one that goes up and down all the time), now when it goes down the top of the rubber catches on the front panel when down. As a result, when it goes up it also catches on the metal panel. It looks like it is of only a few mm, but enough to catch the black headlight rubber surround at the top.
I have tightened everything and all is tight. I was thinking that it may be the metal plate that the rubber surround screws into, that may need tightening. I went inside the bay and tightened the headlight bracket bolts, they are all tight.
Any ides on how I can get the right space would be great guys. When the lights are both down, it looks like the drivers side (the one going up and down OK) has twice the amount of space around the pod and the front panel, than the passengers side does, (the one that catches).
