raise gear ratio
lyledtaylor@gmail.com
raise gear ratio
Postby lyledtaylor@gmail.com » 03 Jun 2014 03:50
Hi I recently requested info re raising diff ratio from 3.9 to3.45 to give my car longer legs on the highway and thanks to everyone I found the info very helpful.I left the diff ratio at 3.9. I am now considering changing the fifth gear ratio from 0.83 to 0.77 am wondering if anyone can tell me how many rpm I might reduce at 60mph (100kph). The wheels are standard 13 inch engine standard 2 litre.
Regards Lyle.
Postby john 215 » 03 Jun 2014 04:39
Loads of RPM / Speed convertors out there like this
http://www.wallaceracing.com/gear-speed.php
Don't forget only a comparison don't mean you achieve these speeds !!
Postby lyledtaylor@gmail.com » 10 Jun 2014 22:34
Thanks John I did't realize there were so many ways to calculate speed/ratios/revs.
I must say this been very helpfull.
Postby silverseven » 11 Jun 2014 01:56
personally I still think changing rear diff ratios is easier and a much better bang for the buck than going inside the trans ......
Postby lyledtaylor@gmail.com » 22 Jun 2014 11:41
Thanks Ron at this stage I've decided to raise the diff ratio to 3.45. I presume you are either running a 3.45 or have changed one at some time.Anyway thank you for your advice.
Kind regards Lyle.
Users browsing this forum: No registered users and 280 guests
