Window Weather Striping
RJS
Postby RJS » 30 May 2014 15:47
Anyone know where I can find door exterior weather striping? Is this also called a window sweep?
Is this something specific for a wedge, or is there "universal" window sweep that will fit?
Thanks for any help,
Rob
Vegas_M
Postby Vegas_M » 30 May 2014 16:22
Exterior is easy, all the normal suppliers carry it. Vict British, Moss, LBC, Wedge Shop. Also available from Rimmers.
Interior strip - now there is more of a challenge. [xx(]
M.
RJS
Postby RJS » 30 May 2014 18:04
whitenviro
Postby whitenviro » 30 May 2014 18:51
I got a pair from the Roadster Factory. They are easy to install, if you have all the clips from your existing pieces. I found I had to do a little razor blade trimming at the front end where it meets with the quarter window.
[/img]
Postby FI Spyder » 31 May 2014 00:05
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Vegas_M</i>
The interior weather strip is part of the original door cards. The door cards I got from Victoria British has the interior strip as a separate piece and clips to the door cards like the outside one clips to the door. They also had the advantage of having an aluminum backing so the door cards don't warp like the original pressed board ones did.
You can also get the door waist seals (outer weather strips) from them.
Postby nick » 01 Jun 2014 21:05
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RJS</i>
Do these look like the right items?
page 57 - #2
http://www.mossmotors.com/SiteGraphics/CatalogPDFs/SP7C-1402_web.pdf
#3
http://www.victoriabritish.com/icatalog/tr/full.aspx?Page=10
The ones form VB are rubbish. The fuzzy stuff is stuck on like tape and comes off very easily. However, I think no matter where you look everyone is carrying the same stuff.
'79 TR7 DHC
'76 TR7 FHC
Postby FI Spyder » 01 Jun 2014 21:25
I got mine from VB, they are fine after 7 years. That was 7 years ago.
Postby UKPhilTR7 » 05 Jun 2014 06:26
I got mine from robsport at a very reasonable price. I also had to do Tue razor blade trick to get them to fit.
Users browsing this forum: No registered users and 348 guests
