Oils seals
Oils seals
Postby REPLIC8 » 18 May 2014 06:11
Took my 7 for it's MOT yesterday, pleased to say it passed with no advisories. Had look underneath to see where an oil leak may be coming from and there seems to be two. One from the front crankshaft oil seal and one from the oil seal at the rear of the gearbox by the propshaft flange. Can't find any info on replacing these, I'm assuming they just prize out & then press another one in? Doesn't look too complicated, or am I missing something?
1981 TR7 FHC
Neil_W
Postby Neil_W » 18 May 2014 06:42
Andy, Don't think it is getting the old seals out it is getting to the seals in the first place.
Front one maybe easier but taking off the crank pulley, radiator etc is quite a job as I think you may need a impact wrench to get the pulley nut off.
Page 73 of the Work Manual on www.tr7.co.uk shows how the seal is replaced.
The Gear Box one maybe easier as it pops out after the prop & flange are off page 194 of manual.
All these tasks are easier with engine & box out.
Me I would invest in a plastic tray or 2 filled with cat litter to catch the drips [:D]
Postby REPLIC8 » 18 May 2014 15:00
Cheers Neil,
A job for winter I think. I'll keep using the drip tray for now. [:)]
1981 TR7 FHC
Postby Beans » 18 May 2014 15:23
No need to remove the radiator or use an impact wrench.
[url="http://tr7beans.blogspot.nl/2013/05/preparing-t-kreng-for-iae.html"]<u><b><font size="2"><font color="red"> This is how I do it </font id="red"></font id="size2"></b></u>[/url] with the engine in the car.
Postby REPLIC8 » 18 May 2014 17:45
Very interesting Beans, I too thought at first it was leaking at the back of the engine, but I'm thinking it's coming out of the front & running to the back. I need to purchase a 38 mm ring spanner as I only have socket which gets caught up in the fan.
1981 TR7 FHC
Postby john 215 » 18 May 2014 17:54
Hi Andy,
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><font size="4">. I need to purchase a 38 mm ring spanner as I only have socket which gets caught up in the fan.
</font id="size4"><hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Or an 1 1/2 AF one mate as same size in old money, should be able to find one at a auto jumble as the same size of the bolt holding on the clutch / flywheel on early front wheel drive A series cars.
Postby REPLIC8 » 19 May 2014 16:41
Thanks for that John, just got one off Ebay for £6. [:D] Seems AF spanners are cheap compared to metric.
1981 TR7 FHC
Postby Beans » 19 May 2014 19:02
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by REPLIC8</i>
... Seems AF spanners are cheap compared to metric ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Over here it's the other way round [:p]
Users browsing this forum: No registered users and 127 guests
