Alternator issue
Alternator issue
Postby UKPhilTR7 » 12 May 2014 11:04
A bit ago, I took my TR to the garage to have some work done on her. When she came back I noticed that the battery light was on, when the car was running. This was not the case before and a friend told me that it may of been due to the fact that some welding may of been done without disconnecting the battery.
So I took it off and put the old one back on. This has been the situation now for about a year or so. However, now I want to fix the newer alternator and put it back on the car. It had done less than 500 miles before the light came on all the time.
I have never looked into it too deep, but could anyone give me some pointers on what to look for and how I can fix this as it would be a shame to throw it away.
Postby dursleyman » 12 May 2014 15:05
If they did welding without disconnecting the battery it will most likely have blown the diodes in the alternator. I am fairly certain I have seen advice on how to test them on this forum somewhere.
You can get new diode packs for most common alternators and they are easy to fit.
Postby UKPhilTR7 » 13 May 2014 23:17
Thanks for that, I have heard it may be the diodes and that is the first thing that I am going to look at, then go from there.
I have taken it off the car to have a closer look and mine looks like the one in the Rimmer website. I have taken the black cover off and can see the voltage regulator. It looks like the regulator is sealed, would I he right in thinking that the diodes are in there?
I brought mine from S&S as an uprated one, but I do not know the ACR rating of it, so I can get the correct regulator, if I buy a new one. On the Rimmer site they sell regulators for the 17 ACR, but I am thinking this may be no good to me if my ACR is higher than 17.
Is there a way I can find out the ACR rating of my alternator, as I cannot see any markings on it or would it say on the regulator when I take it out and have a closer look?
Postby UKPhilTR7 » 14 May 2014 11:06
I took the regulator off and it has only two wires coming from it, black and yellow and the number is VR-LC100. On the regulators in Rimmer there are four cables Yellow, Black, Red and White.
Still no sign of the rating of the alternator on it anywhere. I did hear that there is a way I could tell the rating by counting the number of rings on the centre black partition, but no idea how.
Shooting in the dark here, is this the diodes here:
http://www.rimmerbros.co.uk/Item--i-517231
Or this here:
http://www.rimmerbros.co.uk/Item--i-BAU5264
DutchTriumph
Postby DutchTriumph » 14 May 2014 13:48
Diodes are in the rectifier
Peter
Postby UKPhilTR7 » 14 May 2014 21:25
Thanks for that later last night after looking at it for some time I was starting to think that too and they are easier to get to as the regulator is factory sealed. I can get one of these as they are cheap enough.
The issue now is how can I tell the rating of my Alternator when there is no visible signs on it?
I heard that a 36 amp is classed as 17 acr and a 43 amp output alternator is classed as 18 acr. This is all good, but when it is not on the car, it is a bit hard to verify. My issue is that there is no markings on the alternator itself. If I was to put a 18 acr rectifier on a 17 acr alternator, would this create a big issue?
Postby Cobber » 15 May 2014 07:04
Phil just bin the damned Lucas POS and get a Bosch, I can't remember where the Bosch alternator in mine came from (too long ago) I'll ask my auto electrician mate he might remember.
'98 MG-F, 69'Ford F250.
Postby UKPhilTR7 » 15 May 2014 21:17
I must admit cobber it is looking more and more like I will have to get another one. Next time I will tell the garage to disconnect the battery. I did find out that it was an 18 acr. If you could get the number or name of a bosh one that will diff our connections or can be made to with minimal work, I would be more than happy to get it :)
scarface031
Postby scarface031 » 17 May 2014 02:52
The good news is you get 6 free diodes along with a new alternator ;)
-Justin P
Postby UKPhilTR7 » 17 May 2014 10:55
Oh yes you are right lol
I have decided to go and buy another one. The cost of getting a new one compared to trying to fix the old one, I just thought that it is not worth my time :) Maybe the easy option, but there is too much work to do on my car as it is, without making things harder and longer than they need to be for a few pounds lol
Users browsing this forum: No registered users and 368 guests
