Gear Box Oil Change
Postby bmcecosse » 24 Jun 2014 19:57
Any handy tips on how to get at the fill plug? It's a bl**dy nightmare to reach tucked up above the exhaust ... I remove the exhaust bracket - which helps slightly...but my hands are almost as large as yours Mildred... [;)] if only the fill plug was on the other side of the gearbox... [:(!]
You don't happen to have a 'how to' on changing the rear axle oil??
Stag76
Postby Stag76 » 24 Jun 2014 20:12
At the rear of the gearbox, partly hidden by the rubber mounting, is a drain plug for the pump. If you run the engine and remove this plug, you will flush out any swarf etc. that has accumulated in the pump area.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
Postby bmcecosse » 24 Jun 2014 21:30
That's a handy tip!
Postby dursleyman » 26 Jun 2014 09:38
Mildred, I love the use of the saucepan to drain the oil into. When you use it for cooking afterwards does it affect the flavours?
Users browsing this forum: No registered users and 2 guests
