Anyone tried this power steering setup?
Postby busheytrader » 10 May 2014 07:43
http://www.ebay.co.uk/itm/EASYSTEER-TRI ... 6016.l4276
I haven't been a fan of electric power assisted steering in the past versus hydraulic systems.
Postby Chris Turner » 10 May 2014 09:04
He has 100% feedback all customers seem happy.
I think Im going to give it a try.
www.triumphtrs.co.uk
THE Coca Cola car
TR7 Sprint SJW 539S
Postby UKPhilTR7 » 10 May 2014 11:06
I have seen this before and from what I can see it looks good and from what i have read, it works well. As yet, i have not had the permission from my wife to spend the money lol.
John Wood
Postby John Wood » 10 May 2014 16:23
Most cars have electric power steering today. Can't wait for someone to do an electronic handbrake conversion[:D]
TR7 Sprint SJW550S
TR7 Automatic
dycecooper
Postby dycecooper » 10 May 2014 22:16
I fitted a Corsa electric colum to my TR7V8, best mod I ever fitted
Postby DNK » 11 May 2014 00:10
I have been a follower of this mod a a big proponent.
If I had the cash it would be done.
Then the very pretty, newly rebuilt, unused, PS unit in my garage could go away
Stick a Wedge In It
dycecooper
Postby dycecooper » 11 May 2014 08:29
I bought the Corsa colum from the local scrap yard, £30 I bought a controller I think it was £60 fitted it myself free
smoking joe
Postby smoking joe » 11 May 2014 14:44
I must admit this is something that I would be interested in doing, I cannot believe it is that involved,just a case of knowing in a bit more detail whats involved. dycecooper perhaps when you have the time
this would be an ideal item with instructions to add to the workshop section.
SJ
dycecooper
Postby dycecooper » 12 May 2014 07:33
I have sold the car now so can't take photos but there are two ways of doing it.
I used the complete Corsa colum switches and all. Made brackets to locate it, TR steering shaft went into Corsa colum.
On Hugh's car, Corsa colum was stripped down and TR top half was grafted on ( this involves welding) retaining the TR switches and steering wheel.
In both cases you require a controller for it, this enables you to adjust how light or heavy the steering is and you can even switch it off altogether.
Postby john 215 » 12 May 2014 18:43
I see that ' prackers ' blog he has a Corsa column to fit to his -
http://www.forum.triumphtr7.com/topic.a ... C_ID=20079
TRJIMBO
Postby TRJIMBO » 12 May 2014 19:46
I put the hydraulic system on my TR7V8 that is available from another company that makes power steering for classic cars. It makes the driving experience much more pleasurable. There are pics of it on Robsport's FB page. Would be interesting to compare the feel of it to electric power steering.
prackers
Postby prackers » 13 May 2014 00:48
Yea, but I have no experience with them... yet, but a friend has fitted several to mk. 1, 2 and 3 escorts, TR6's, to name but a few, and reports that generally they work very well, but time will tell.
I am not sure if I am going to use the complete corsa set up yet or graft the TR switch gear etc. to the corsa column, I'll start with the corsa and see how it looks/feels.
I paid £70 for the column (eBay) and a further £20 for the input emulator:
toneinblack
Postby toneinblack » 13 May 2014 09:58
theres a few corsa columns on ebay at the moment around the 40 to 50 pound mark, looks like there is 2 different versions tho, £50 for the column and £60ish for the control box that has been mentioned above seem a lot cheaper then the £500 on ebay but would be nice to see instructions for both.
DaveB
Postby DaveB » 13 May 2014 15:41
I put a hydraulic system on my Grinnall using a modified Rover SD1 rack (one of Rimmers recon ones), SD1 pump, custom adaptor from TR7 column to rack and custom hoses. Works great.
Advantage of the SD1 rack is that it is less than 3 turns lock to lock whereas the TR7 rack can be up to 4 depending what you've got so although lighter means a lot of turning.
Just my opinion of course
Dave
paulheritage
Postby paulheritage » 16 May 2014 21:51
I'm currently doing the Corsa B conversion and have been taking pictures so will post once done (prob after the Summer now when car off the road).
The full cost of all parts is less than £100 but there's quite a bit of work amending the Corsa and TR7 parts, not withstanding the main issue is that the power steering motor bracket is where all the torque is required so needs to be mounted very well under the dash. Effectively the steering wheel is sending a signal to the motor to turn the wheels.
Cheers Paul,
1976 TR7 2.0 FHC, ACG 3115 - Java Green (on the road)
www.TR7.co.uk
Users browsing this forum: No registered users and 344 guests
