Carburettor rubber mount
nigel
Postby nigel » 09 May 2014 05:25
http://home.comcast.net/~rhodes/TR7_adapters.html
can anyone see why this would not work as mine have cracked open again. I could make these but they must be rubber for a reason.
bonnietiler
Postby bonnietiler » 09 May 2014 05:38
Just as an aside...if you are prone to filling up with "cheaper" Supermarket fuel then one of the reasons that it is cheaper is the higher content of Ethanol which of course destroys rubber with a passion...Main supplier forecourts are more expensive and one of the reasons is that they do not load the fuel with the afore-mentioned cost cutting additive.
Regards
Bonnietiler
Postby UKPhilTR7 » 09 May 2014 06:27
I had some new mounts on my car before she went to a garage for some work. When my girl came back they were split. Must of been a mechanic leaning on the carbs, putting pressure on the mounts and splitting them. Try convincing the garage though. Since then I have always put cable ties around the mounts to give them more support.
I was looking into these as an option as I was going to order from someone who also made them. I didn't realise that they would not work as they always needed to be rubber
Postby Chris Turner » 09 May 2014 06:57
I would like to try a pair but the import tax from the US makes them very expensive.
www.triumphtrs.co.uk
THE Coca Cola car
TR7 Sprint SJW 539S
Postby Hasbeen » 09 May 2014 08:10
Mildred has tied her carbs to the manifold, sandwiching the rubber mounts, with hose clips I think.
Others have strengthened the mounting with heavy zip ties.
Gluing the rubber, then reinforcing as above should do the trick.
On the other hand I have had SUs & Webbers on solid manifolds on a number of engines, with no problem. Either should work well.
Postby TR Tony » 09 May 2014 08:27
I have heard a couple of TR7 owners in the States give good reports on these mounts.
To import into the UK I reckon it would cost about £140 - £150 at current exchange rates with the extra postage, import duty, VAT & the Post Office handling fee. But then these mounts should last forever, not to mention the saving in time & trouble replacing poor quality rubber mounts.
EDIT might be a bit less as import duty does not apply on items with a value of less than £135. Still have to pay VAT & handling fee though.
Postby dursleyman » 09 May 2014 09:51
The Dolomite boys use the alloy mounts with good effect and their owners club sells them for £67.99 pair.
MikeRotherham
Postby MikeRotherham » 09 May 2014 10:38
After seeing Mildred's I'm currently trying this:
http://www.amazon.co.uk/Draper-55592-Ho ... +hose+clip
You just cut to size
Regards
Mike.
DutchTriumph
Postby DutchTriumph » 09 May 2014 15:11
I've fitted something like this to my TR7, no problems at all.
http://www.forum.triumphtr7.com/topic.a ... hichpage=2
Peter
supercass
Postby supercass » 09 May 2014 21:16
<i>[quote]<i>Originally posted by bonnietiler</i>
Just as an aside...if you are prone to filling up with "cheaper" Supermarket fuel then one of the reasons that it is cheaper is the higher content of Ethanol which of course destroys rubber with a passion.</i>
The ethanol content of fuel has nothing to do with perceived quality. A premium brand (Shell for e.g.)is just as likely to contain similar amounts of ethanol. Suppliers do not have to give the ethanol content which is not helpful for those of us with older cars. Also ethanol destroys many other items such as the delicate circuitry on the fuel level sender unit.
supercass
bonnietiler
Postby bonnietiler » 09 May 2014 21:54
I'm sure you're absolutely correct I am an idiot
I know nothing about the subject
I shall refrain from further comment
Postby Workshop Help » 09 May 2014 23:45
To illustrate someones point in this topic, here is a photo of the two hose clamps holding the carburetor set to the manifold.
For those poor souls with the new bubble-gum carburetor mounts, Please rush out and get two 3" to 4" diameter clamps and secure your carb set in place.
You'll sleep better at night and so will I.
Postby FI Spyder » 10 May 2014 01:41
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by supercass</i>
Actually Shell is one of the few local stations that has ethanol free gas (premium). Co-op is another one. This no doubt will vary from locale to locale. Often there are web sites that show which stations are alcohol free and which grade. At least around here.
Websites like these let you know, I'm sure you can find one for your area. There are lots out there.
http://pure-gas.org/index.jsp?stateprov=BC
Postby john 215 » 10 May 2014 05:03
Our Ethanol content is now as high as 10% here in ' The Old Country ' it not only attack fuel hoses but also metal components in the fuel system, it helps promote corrosion between to dissimilar metal ie. alloy and brass as in carb jets etc. Another slight side effect is because ethanol contains oxygen it actually slightly weekens the mixture. The bad news does not end there, it is also tends to be hydroscopic, it will absorb moisture from the atmosphere, so potentially introducing water into your fuel system and we all know what that does to our fuel tanks only a very small amount granted but it should not be there !
The big brand company's say they only use 5% its the super markets that tend to stick in more, once again you get what you pay for !
Postby UKPhilTR7 » 10 May 2014 10:56
I was going to post a picture of the cable ties on my carbs, but thanks to the link posted, I do not have to lol
So the main questions from reading this, is how can we get them over here cheaper, has anyone contacted the guy via his email address and dound the dolly ones be OK for us and how can we get them.
Users browsing this forum: No registered users and 328 guests
