Front Console Ground Wire
kermit
Postby kermit » 24 Apr 2014 11:41
I pulled the front console off to replace the radio and found a black ground wire had come loose and not sure where it goes. The wire comes from the harness (right side of the heater box) that feeds the front console lighting panel, cigar lighter & AC switches.
The lighting panel has a single red/white wire coming out of the same harness but no ground wire.
Should the ground wire be tied into this panel somewhere?
1980 TR8 DHC - Poseidon Green
1980 TR7 DHC - Brooklands Green
DutchTriumph
Postby DutchTriumph » 24 Apr 2014 14:05
Isn't this the ground, to put on the bolt on the backside of the radio?
Peter
Postby DNK » 24 Apr 2014 14:12
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DutchTriumph</i>
Isn't this the ground, to put on the bolt on the backside of the radio?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Think he noted that one as different
Stick a Wedge In It
kermit
Postby kermit » 24 Apr 2014 14:35
The ground from the radio to the chassis bolt is separate.
How is the console lighting grounded?
kermit
Postby kermit » 25 Apr 2014 11:23
Took a closer look at the 4 light fixtures on the console bar and noticed fragments from a broken wire on one of the lights. Seems to make sense that there would be one R/W wire and one B wire coming from the loom and connecting to one of the 4 lights. The R/W and B wires then jump over to the other 3 lights.
Users browsing this forum: No registered users and 333 guests
