Got off my bum and opened the garage door
Postby stevie_a » 06 Apr 2014 15:56
<font color="teal"><b>Got off my bum and opened the garage door, the first time since end of September.
Job to do was one recently spoke about in a recent topic " fuel sender "
got the car up on the axle stands
had a look and with a BIG bucket undid the fuel pipe, as i had no idea how much fuel i had in the car
I drove it to billing and back with no fuel gauge (a bit mad i know)
I estimated i had about 15 liters, as it turned out i had about 8 that came out.
The tank looked in great condition.
Hit of the retaining ring and let the last of the fuel out.
then removed the sender unit and compared it to the new one
OLD
NEW ( was surprised to see wires rather than the metal connectors
old and new together
Fitted and with new spade connectors it is all well after putting 5 liters of fuel in with no leaks, just to reapply the underseal.
</b></font id="teal">
Postby FI Spyder » 06 Apr 2014 16:09
How did you determine that the fuel tank was in good condition? As they rust from the inside out, without dropping the tank did you have a remote viewer or use a mirror?
Postby stevie_a » 06 Apr 2014 16:35
<font color="teal"><b>used one of these
and then one of these Flexible Magnetic Pickup Tool</b></font id="teal">
mb4tim
Postby mb4tim » 07 Apr 2014 16:36
I used something similar, buy way cheaper (if you have a computer/laptop close by - a USB borescope.
They can help you see things that are hidden.
-Tim
Postby stevie_a » 07 Apr 2014 18:22
It might be cheaper to buy, but mine was borrowed which is cheaper again. [:D]</b></font id="teal">
Postby Hasbeen » 07 Apr 2014 22:47
Steve did I get it right. After draining the tank by the fuel pipe at the engine bay end, there was still fuel above the outlet hole in the tank.
This should not be the case, as the pipe end is below the tank, & I have always almost totally drained tanks this way, as the fuel continues to syphon to the bottom of the tank.
If your tank was still half full there must be an air leak in your system somewhere, which allowed the syphon to be broken. Of course this could have been in your old pickup, but I would want to find the reason, if it were mine.
Postby stevie_a » 08 Apr 2014 04:53
<font color="teal"><b>No i took the pipe off at the tank. [:I]
it was only a tiny bit that came out of the outlet hole</b></font id="teal">
Postby stevie_a » 18 Apr 2014 05:05
<font color="teal"><b>Image
Ok still have no gauge, i can only presume that the mice have been here again.
so i am going to run a wire from the tank to the dash.
there are four wires on the sender unit where do these go ?
the green and black - does this go strait to the gauge or does it go somewhere first?
the two black wires - i take it to be earth wires, do these go straight to earth or do they go somewhere first?
as for the other wire - not got a clue where this goes
i am off work and no plans for this weekend ( for once)
so hope to go out to the car and spend some time on it.</b></font id="teal">
Neil_W
Postby Neil_W » 18 Apr 2014 12:47
Have you had a look at the Manuals Wiring Diagram - the Work's one on line ?
http://www.tr7.co.uk/pdfs/TR7.pdf
Page 341 has the colours & instruments attached to the fuel tank unit to Fuel gauge.
109 Fuel gauge
98 Fuel tank
99 Low Level Delay
Postby dursleyman » 18 Apr 2014 14:46
Does your low fuel warning work?
Might not be the wiring but worth a check. I had problems and it turned out to be the gauge. Only found that out when I swapped the gauge for a spare and it now works fine.
1980 TR7 Sprint DHC
Postby jclay (RIP 2018) » 19 Apr 2014 03:11
When you say that you have no fuel gauge, do you mean that it reads totally empty or totally full? If it says totally full, then the green/black wire from the sender to the pod is shorted in the run(probably where the wires go through the body at the top of the driveshaft tunnel).
If the gauge reads totally empty, then the black wire on the sender is probably not making good contact to earth, or the green/black is not making good contact at the sender or lastly, you have the wires reversed on the sender. I can see from your photos that one of the green wires has been crimped close to the sender unit. Has the wiring been totally cut and the insulation just holding it together?
Low fuel warning light: Note that the lever that holds the float on the sender unit rests on a metal tab when it hits bottom. This is actually a switch and connects to the green/orange wire. When The float support wires touches the rest, it complete a circuit to ground through the sender. The green/orange wire goes to the delay unit that is connected to the back and above the pod. when it receives power a given lenght of time, it turns on the warning light, other wise it would be blinking on every time you took off to fast from a light.
Postby stevie_a » 19 Apr 2014 17:31
<font color="teal"><b>put my modified dash back in, ran a wire from the tank strait to the gauge (after market one)
put on new live and earth and all working Image
voltmeter now working Image
rev counter now workingImage
clock working Image
next to wire up temp gauge (after market)
then check all bulbs work correctly, this is a heavily modified dash </b></font id="teal">
Postby stevie_a » 27 Apr 2014 10:24
<font color="teal"><b>was out today again to have a look, took a deep breath and started again
now have all gauges including a clock, now need to try and get all the warning light to work.
Oh by the way i did find the problem ...[}:)]
yet another dead one of these little fellas sitting at the end of the bulkhead just below the carpet...
I have traps, electronic sound wave things and poison down, but no they like in the car.
this is what they did the last time to my hats in the glove box
Image</b></font id="teal">
Postby Hasbeen » 27 Apr 2014 12:07
What a nice bloke you are Stevie, putting that cap in there for nest building materials, for your little guests.
Postby john 215 » 27 Apr 2014 12:23
Hi Stevie,
You need a cat mate [:D]
Users browsing this forum: No registered users and 181 guests
