Nose Decal Position
Stevie P
Nose Decal Position
Postby Stevie P » 31 Mar 2014 07:55
Hi guys
Is there a correct position for the nose Laurel Leaf decal?
Anyone got the dims if yes?
Thank,
HowardB
Postby HowardB » 31 Mar 2014 09:24
There was a series of articles in TR Driver about 5 years ago that gave all the dimensions. If you are lucky someone will be able to find a copy and email you the dimensions.
Howard
Postby Workshop Help » 31 Mar 2014 12:17
Have you given any thought to using a TR8 decal instead? I always considered the laurel leaf design to be tacky.
Postby nick » 31 Mar 2014 15:25
Agreed. I used the "TR7" decal after a recent respray on the yellow car. I now have one of each and will change the brown car one as well after it is resprayed.
'79 TR7 DHC
'76 TR7 FHC
Postby stevie_a » 31 Mar 2014 16:08
<font color="teal"><b>This is what i did
found the center lines
Then the centre of the Laurel Leaf</b></font id="teal">
Postby Chris Turner » 31 Mar 2014 17:49
I think the laurel looks great, your positioning is spot on Stevie.
www.triumphtrs.co.uk
THE Coca Cola car
TR7 Sprint SJW 539S
Postby stevie_a » 31 Mar 2014 19:54
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Chris Turner</i>
your positioning is spot on Stevie.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
<font color="teal"><b>Thank's Chris [;)]</b></font id="teal">
Stevie P
Postby Stevie P » 31 Mar 2014 20:21
Stevie
How far from the bonnet edge is the top of the Laurel?
Postby stevie_a » 31 Mar 2014 21:24
<font color="teal"><b>Don't do it that way
measure from top ( near bonnet) to bottom (near bumper)
get the 50% mark do the same with the width i did it from edge of the light panel
that gave me the center do the same with the laurel.
look at this photo again and you see what i mean.</b></font id="teal">
jrich4411
Postby jrich4411 » 01 Apr 2014 00:15
Steve - is the decal just the wreath & "Triumph"? or is their clear decal keeping it all together that stays on the car after you remove the backing?
'80 DHC
Chevy V8 up front
Ford rear end down back
Lucas wiring all over
Stevie P
Postby Stevie P » 01 Apr 2014 04:22
It's still sandwiched between the front and backing sheets, but as far as I can tell it's the laurel only, many small pieces, not one big transparent sticker.
If that is what you meant.
Stevie, I got the meaning of he 4 Marks on the masking tape, but yours does look biased to the top (bonnet) line.
May be just an optical illusion!
Postby stevie_a » 01 Apr 2014 04:57
<font color="teal"><b>must be optical illusion as it is exactly in the middle.
jrich4411 as Stevie said no clear decal keeping it all together just many small pieces</b></font id="teal">
Triumph TR7V8 coupé
Postby Triumph TR7V8 coupé » 01 Apr 2014 09:55
The original position of the laurel isn't in the midlle but slightly more upwards, I've got the original (Leyland) measurements at home, If I don't forget I will search them in the evening and email you a copy tomorow.
Greetings, J.
Postby Maxwell » 01 Apr 2014 10:16
I have sourced the definitive booklet detailing the correct decal positions, should be with me within the next couple of days. However, it seems that these were 'hand-applied' in the factory and no two are exactly the same anyway, so don't worry!
Maxwell TRDC Editor
2.0 TR7 FHC \ Current
1.8 Mazda MX5 \ Current
Triumph TR7V8 coupé
Postby Triumph TR7V8 coupé » 01 Apr 2014 18:23
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Triumph TR7V8 coupé</i>
Greetings, J.
had a look in my shed and found the article but it says that measurements have been taken from different cars and none of them was the same, according to the folder I have there is no documentation from the factory how to position the nose decal. Also, the folder I have only speaks of the TR8 decal.
Greetings, J.
Users browsing this forum: No registered users and 27 guests
