Replacing the fuel sender unit
RJS
Postby RJS » 27 Mar 2014 13:03
I am planning on changing out the fuel sender unit this weekend. I have read over jclay's write up (thank you for posting these great articles).
My only question so far is: Should I use any sealer on the rubber gasket? If yes, what kind?
http://www.triumphtechnical.me/triumphtechnical/Fuel_Tank_Sender.html
Rob
darrellw
Postby darrellw » 27 Mar 2014 13:55
I did not use any sealer on mine, and haven't had any problems.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby FI Spyder » 27 Mar 2014 13:55
No sealer is necessary. I don't think the seals are even rubber but some composite that is gasoline resistant although we often generically call them "rubber". When you tap in the ring by the tangs tap with a flat punch close to the ring so you bend them as little as possible. If the seals are deteriorated or too compressed, new ones might be a good idea.
RJS
Postby RJS » 27 Mar 2014 15:37
The new unit came with a seal, so I was not planning on using the old one.
Postby Beans » 27 Mar 2014 18:32
Just use the supplied seal.
And make sure your tank is empty ...
RJS
Postby RJS » 27 Mar 2014 18:46
and no smoking....
Postby john 215 » 27 Mar 2014 18:50
Supplied seal only and check the rubber pipe as they tend to perish in modern fuels
RJS
Postby RJS » 27 Mar 2014 21:44
I replaced the hose several years ago after it failed completely. Went from a small drip to gushing gas in only a few minutes. Luckily there was not a fire when it gave up.
Living in Arizona is great when you talk about rust free cars, but our hot dry climate is not good for anything rubber.
Rob
Postby jclay (RIP 2018) » 27 Mar 2014 21:52
Use the NEWER fuel injection hoses.
RJS
Postby RJS » 29 Mar 2014 13:32
Done...
It is always a nice feeling when it goes as expected.
Thanks for all the help.
Rob
