clock repair
clock repair
Postby nick » 17 Mar 2014 23:30
Anyone have any luck fixing one that has these symptoms? When connected to a 9v battery or installed in the car, the pendulum on the clock operates. But the hands don't move. I can move the hands with the set cable but otherwise they are still.
I have read the pdf posted by Greg that goes into detail on how to fix these clocks but his fixes are for an electrical problem where the pendulum doesn't move. My pendulum moves OK but hands don't.
And at the moment I don't want to add an oil presure gage in it's place.
'79 TR7 DHC
'76 TR7 FHC
darrellw
Postby darrellw » 18 Mar 2014 00:17
My guess would be cleaning and oiling the gears. But I can't provide any specifics, someone did mine for me.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby john 215 » 18 Mar 2014 05:06
Hi Nick,
Have a read of this PDF, one way round the problem, the other is to throw the clock away and install a oil pressure gauge !
http://www.smallscalerailway.com/TR78clock_2April08.pdf
Paul_TR8
Postby Paul_TR8 » 18 Mar 2014 05:39
There is a company that will change the internals to solid state so that the clock will work and keep time.
http://www.speedycables.com/
UK company
g4zur
Postby g4zur » 18 Mar 2014 06:02
Thanks for that Paul. Have sent them an enquiry.
Regards Gareth
G.P.Albrighton
Postby FI Spyder » 18 Mar 2014 12:12
Sounds like the clock is TU not just a weak pendulum like the link fixes. Since you have nothing to lose I'd clean and lube the insides. Not sure how I'd do it probably the same way a watch repairer does. I'd search the web to see if their secrets are revealed. 2nd to that, there must be plenty of clocks out there that have weak pendulums/dirty contacts (or even working ones that could be had when people put in their oil pressure/worry gauges.
Postby nick » 20 Mar 2014 19:26
Well, I got it running with by squirting some electronic cleaner in the gears. But then I found the second hand lose so I tightened it and pressed it back on with a bit of force. After that the clock never ran again. One should leave well enough alone. I took it apart and found one of the gears was lose on its shaft. I think the thing has had it.
'79 TR7 DHC
'76 TR7 FHC
Postby Workshop Help » 20 Mar 2014 23:37
For a paltry $4.00 or so, trot on down to Walmart and get a stick-on digital clock in the automotive section of the store. Mount it in between the switches in the middle of the dash. In place of the clock, install your choice of gauge. Oil pressure, cylinder head temperature, vacuum gauge, or even a picture of your wife, we'll leave that up to you.
Postby FI Spyder » 21 Mar 2014 12:07
Sounds like the clock is truly TU. I would look for on eBay, none there at the moment except for an exorbitant $80+ dollars. Better yet you should be able to get one from an auto wreckers or some one who is parting the car for next to nothing. Post a request in the parts section. There must be lots of people that have one lying around. Mine just keeps on ticking reliably and is an important item in the cockpit as I haven't worn a watch since I left IBM in 1980. Digitals just don't cut it in 1980 although it's fine in the'91 Integra.
Postby nick » 23 Mar 2014 15:10
I decided to stay with the clock and not convert to oil press. Scored one ebay for US$20. The guy said it runs. We'll see.
'79 TR7 DHC
'76 TR7 FHC
Users browsing this forum: No registered users and 373 guests
