interior door lamps
supercass
Postby supercass » 16 Mar 2014 16:54
Check your earths first. The second switch was not used in the UK. supercass
Postby silverseven » 16 Mar 2014 23:01
first thing would be to clean your contacts [;)]
Postby john 215 » 17 Mar 2014 05:11
Hi Chrichie,
[8D] WELCOME TO THE BEST TR7 / 8 FORUM IN THE WORLD [:D]
I would also check the wiring connectors, seen the wires broken down to almost a single strand at these points. Use a jumper wire from the earth connector to a good earth and see if light brightens, this will tell you if live or earth problem.
Users browsing this forum: No registered users and 299 guests
