Well This is Very Scary
Postby DNK » 01 Mar 2014 17:57
Was walking behind the car yesterday when I see this.
It had been pretty windy and maybe(??) blew from underneath.
Does anyone recognize it?
My first thought was a brake part
It's about 7/8ths" (22-23mm) long
Stick a Wedge In It
Postby RUDDY » 01 Mar 2014 18:03
Looks very much like a short door hinge pin ?
But far too short for the bottom hinge.
Postby DNK » 01 Mar 2014 18:07
Good point
I'll look
Stick a Wedge In It
Postby DNK » 01 Mar 2014 18:11
And the winner is!!!!
Ruddy
Stick a Wedge In It
Postby FI Spyder » 01 Mar 2014 19:24
Not so scary then. Looks like your TR7 is trying to turn itself into a Mini Moke. At least it's got the right brake pads for it.[:D]
Postby DNK » 01 Mar 2014 20:12
You think there any problem with just pounding it back in?
Stick a Wedge In It
Postby Beans » 01 Mar 2014 22:14
As it is (almost certainly) the lower pin from the upper hinge,
chance is it will fall out again.
Ad a <u>little</u> weld to it and it will remain in place.
Postby DNK » 01 Mar 2014 23:28
Weld??
Stick a Wedge In It
Postby Hasbeen » 02 Mar 2014 02:38
If you don't want to burn the paint, try getting everything very clean, lubricating the moving area, & use Loctite on the non moving part.
Postby FI Spyder » 02 Mar 2014 04:10
You would want to clean it/hinge up good first in contact area as nothing sticks good to dirt/grease.
I was wondering if you could tap/squish the splines out a little bit with an anvil or vise and a flat punch while someone (third hand) held it on the vise. That would give it more bite. Don't know if it would work, just a thought.
Users browsing this forum: No registered users and 226 guests
