Made in UK - Rear Motor Mounts
Postby jclay (RIP 2018) » 09 Feb 2014 13:59
<font size="1"><i>Jim TenCate, President of TWOA asks:</i></font id="size1">
"We (TWOA) have a question... all the latest rubber gearbox mounts are made in Taiwan or India. The originals were made in the UK.
Anyone have ANY idea who might have made the originals, some company in the UK we presume? The ones I have are Rover parts... and clearly say Made In UK.
We wonder by whom and if that company is still around or has the tooling still or, etc!
Inquiring minds want to know,[;)]?
Jim"
Postby Beans » 09 Feb 2014 14:52
If I rememeber correctly they were produced by Metzeler
Postby Workshop Help » 09 Feb 2014 18:19
Please be advised there is a superior replacement mount awaiting you at your favorite auto parts store. It is made by 'Anchor', Part # 2675. You will need to trim off the end of the mounting tabs for it to be a perfect fit. Should you desire a taller shift lever knob, fit the mount with the tall side up. For a lower shift lever knob, install it with the short side up.
If you have had to re-tap the mounting hole on the LT77 rear extension to an oversize bolt, it is easy to drill out the aluminium hole in the mount to fit. Total actual time to replace my rear mount, including cleanup and reaching for a beverage and cookie afterwards, was 30 minutes.
I have no idea for what this mount was originally intended, but it works perfect on a TR7.
Postby jclay (RIP 2018) » 09 Feb 2014 19:12
Thank you both,
Posts forwarded to Jim!
Postby Beans » 09 Feb 2014 19:22
... made by 'Anchor', Part # 2675 ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Thx for that info, might be useful in future [;)]
jeffremj
Postby jeffremj » 09 Feb 2014 20:01
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I am not sure that Metzeler is British. My thoughts on this point to Metalastic as a major UK supplier of such stuff, and Dunlop seem to hold the trademark. Dunlop India still mention Metalastic, so if the new Indian ones say Metalastic, you should be OK - complain to Dunlop if they are not.
Postby jclay (RIP 2018) » 09 Feb 2014 22:46
http://www.rockauto.com/catalog/moreinfo.php?pk=315251
Postby silverseven » 09 Feb 2014 23:23
off topic to Jclay here;
Instead of quoting his personal emails, why don't you suggest to Jim to sign up directly to the site ???
HDRider
Postby HDRider » 10 Feb 2014 00:10
It fits a 1995 Volvo 940 Automatic
Napa Auto part number BK 6201238
Edward Hamer
Petaluma CA
Postby jclay (RIP 2018) » 10 Feb 2014 04:14
Actually, he does belong, he is just used to using the TR7/8 mailing list. I will suggest it.
Postby silverseven » 10 Feb 2014 15:11
I understand how hard it is to break old habits .....
- but we will get more traffic if they come over and post here too [;)]
Postby Odd » 11 Feb 2014 04:18
And vice verse - although that wouldn't be as visible a difference... [8D]
/Odd
Member on both for years/decades...
whitenviro
Postby whitenviro » 12 Apr 2014 17:23
To dredge this topic back up, I replaced the rear mount when I redid the clutch system of my car. The gearbox noise inside the car increased dramatically. Talking to Jim TenCate few weeks ago, he has been trying to source softer mounts because the new ones coming from India are much too stiff. Especially when changing from a mount that has been soaked in oil for 30 years.
To soften some of the difference, last night I installed silicone washers on the four studs that hold the crossbar to the car body, and a thin rubber washer on the main bolt at the top of the spacer. It made a big difference in the sound inside the car.
I'm not sure the silicone washers do much because they are so soft they squash flat and the crossbar is still pulled tight against the body. But I might even add another washer onto the main bolt to see if that helps even more, or add rubber washers where the mount sits on the crossbar.
[/img]
Peter Nuss
Postby Peter Nuss » 12 Apr 2014 23:35
You are going to get stress cracks in your floor boards and worn threads in your transmission if you keep this silicon/rubber washers mounted the way you have posted here.
TR8
whitenviro
Postby whitenviro » 13 Apr 2014 02:25
I kind of doubt that because they are so soft that when torgued up, they squash too flat to do much of anything anyway. The cross bar is in contact with the body over the whole width of the crossbar. The last picture is before tightening the main bolt, just to show the washer in place.
[/img]
