Turn Indicators
kermit
Turn Indicators
Postby kermit » 07 Jan 2014 17:12
The turn indicators on my car don't reset themselves. The previous owner put an early pre 79 right hand side indicator on my 80 TR8.
This is what is on the car:
Do I have to scrap this and get a post 79 left hand side one to make it work correctly?
This is the one that should be there:
80 TR8 DHC
Poseidon Green
RJS
Postby RJS » 07 Jan 2014 18:46
From what I understand, either switch will work.
I had similar issues in the past.
http://www.forum.triumphtr7.com/topic.asp?TOPIC_ID=18675&SearchTerms=turn
FYI - from the picture in that post, the ball bearing / spring go directly below the spot where the pointed plastic w/spring goes.
Rob
Postby Workshop Help » 07 Jan 2014 18:58
First things first. We do not ever scrap TR7 parts. They go in the box of spares for use or sale at a later date.
Second thing is, are the connectors the same? If so, it should work.
kermit
Postby kermit » 07 Jan 2014 19:39
RJS - That sounds right as most of the big suppliers list both parts as working in the late models. Any idea why it is not resetting?
Perhaps a spring is not set correctly.
Mildred - I had to spend the recent winter break organizing all of the parts that have been compiled over the years. Need a bigger garage.
80 TR8 DHC
Poseidon Green
RJS
Postby RJS » 07 Jan 2014 20:19
I hate to say this, but open it up and look inside.
Make sure you are somewhere where you will not loose the parts.
When you open it up, hold the base level, and lift up the metal part (it will come up like it is hinged because one end is held down).
In the second picture down (and fourth pic), there is a piece with white "catches" sticking out. The black hollow piece follows the steering column, and has a piece sticking out that will push the white "catch" back to center when it turns.
My guess is either the white catches are broken, or the springs pushing down on the ball bearing and pointed plastic are too strong so the pressure on the catches is not enough to press it back to center.
If the part holding the white catch is broken, let me know. I am pretty sure I have another.
Also, I know that both version have the same plug.
Rob
Postby Cobber » 07 Jan 2014 21:25
Hang on a minute just let me get this straight in my mind here.
Being in the US you have a LHD (left hand drive) car.
Is it not, desirable and indeed accepted practice to operate the indicators (turn signals) with the left hand on a LHD car? Thereby keeping your right hand free to change gear.
So why on earth did Leyland change the indicators to the right hand side of the column on LHD cars?
They did the opposite here in Oz where we drive on the right (and correct) side of the car, here the pre 80 cars had the indicators on the right side of the column and then they changed them over to the other side. So on our 1980 and later RHD cars we have to indicate with the same hand we use to change gears with!
It's madness, I tell you... utter bloody madness!
I changed mine over
'98 MG-F, 69'Ford F250.
RJS
Postby RJS » 07 Jan 2014 21:46
Every car I have ever seen in the US has the turn stock on the left side (including my Triumph).
It us just upside down in the picture.
Rob
Postby Workshop Help » 07 Jan 2014 22:39
Drive on the left! Drive on the right! Shift with this hand! Shift with that hand! It's all too much. My friend Mavis drives her big bomb Buick down the middle of the road, and has for years. Not only that, she has always driven while looking thru the steering wheel. She's all of 4'10" tall with a sparkling personality. Everyone in town knows to get out of her way when she goes to the store.
rgsSpider
Postby rgsSpider » 08 Jan 2014 01:05
My 1980 Spider has the first one, on top of the blue box. That is the correct stalk for a 7, was it different for an '80 TR8?
Randy
Image Image Image http://rgstr7spider.tumblr.com/
RJS
Postby RJS » 08 Jan 2014 12:38
From what I understand, all 79 and before had one style, and all 80 and after had a different one. Nothing to do with TR7 vs TR8.
If you look closely, you can see the differences:
http://www.thewedgeshopstore.com/categories/Interior/?sort=featured&page=2
Postby FI Spyder » 08 Jan 2014 16:54
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rgsSpider</i>
My Spider has the second one, mind you I replaced it right away as the headlight dimmer wasn't working so wasn't aware if there were too types as I was new to the scene. I can't remember if it was the same or different, didn't register at the time. So if it's different they both work. It takes a larger turn of the wheel to turn signals off compared to Toyota or Acura.
Build date July,1980, Solihull.
Postby Beans » 08 Jan 2014 17:52
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by kermit</i>
... Any idea why it is not resetting? ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Plastic sleeve ...
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RJS</i>
... The black hollow piece follows the steering column ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
... wrong way up, there's a mark that should be pointing to the stalk
Turn it through 180º and refitt steering wheel.
kermit
Postby kermit » 09 Jan 2014 14:23
Beans,
I bet that is the problem. The PO had replaced an aftermarket wheel with a TR7 wheel before I got it. The wheel is also not perfectly centered. I will pull it off this weekend to take a look. Hopefully it warms up a little.
Postby jclay (RIP 2018) » 10 Jan 2014 19:53
There is a metal finger inside the hub that should be pointing down when the hub is installed properly.
RJS
Postby RJS » 10 Jan 2014 22:53
Yes to Clay.
My previous owner had the hub upside down. If you have that wrong, it will not reset for left(?) turns unless to you turn extremely sharp.
Users browsing this forum: No registered users and 295 guests
