oil guage
gary mc knight
oil guage
Postby gary mc knight » 14 Nov 2013 17:54
Hi all can any one tell me how this would work got a set of 52mm digi clocks says have to conect green wire to oil pressure sensor but tr does not have sensor what do I conect it to or what do I need to do thanks
Postby DNK » 14 Nov 2013 18:42
Doesn't have a Sensor????
I would hope it does!!
Stick a Wedge In It
Postby DNK » 14 Nov 2013 18:48
It's that silver thing.
Mine has 3 wires most have 1
Stick a Wedge In It
Postby DNK » 14 Nov 2013 18:50
Can you post the wiring instructions
Is the G wire the power wire?
Stick a Wedge In It
gary mc knight
Postby gary mc knight » 14 Nov 2013 18:55
Has three wires red black and green do know how to post sorry
Postby DNK » 14 Nov 2013 19:04
Why the oil pressure gauge?
Stick a Wedge In It
Postby Beans » 14 Nov 2013 19:27
TR7 only has an oil pressure <u>switch</u>, which switches on the oil pressure light when the oil pressure gets low.
You need to fit a T-piece/adaptor so you can fit the pressure switch and an oil pressure sensor ...
gary mc knight
Postby gary mc knight » 14 Nov 2013 19:28
Got 3 clocks water temp oil temp and volt s that's why its oil on my car has oil sensor then center nut. Then a blank space could i tap into that do you think
Postby DNK » 14 Nov 2013 19:31
Now I'm confused
think there is a language question here
Clock=Image
Stick a Wedge In It
Postby saabfast » 14 Nov 2013 20:16
'Clocks' is a term for dials or gauges.
As noted above you need to remove the existing oil pressure switch and replace it with a 'T' piece (readily available if you google it, just need to get the right size which I can't remember). You then fit the existing oil pressure SWITCH into one port of the 'T' and the SENSOR for the gauge in the other. The gauges normally come with the sensor but if you do not have it check the site of the gauge manufacturer. They are also generally available but not sure if they need to be matched to the gauge (mine is capillary, not electric).
Saab 9000 2.3 LPT Auto
gary mc knight
Postby gary mc knight » 14 Nov 2013 20:18
Thank you will give that a go will let you know how I get on
gary mc knight
Postby gary mc knight » 14 Nov 2013 20:40
Ok do you know where i can get one of. Those and name of. The part i need thank you
Postby DNK » 14 Nov 2013 20:55
Never heard it used that way
What is the origin?
Stick a Wedge In It
Postby FI Spyder » 14 Nov 2013 23:58
What is the origin?
English. [:p]
Postby Beans » 15 Nov 2013 14:59
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by gary mc knight</i>
... do you know where i can get one of. Those and name of. The part i need thank you ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
If I remember correctly I got mine from Europa Spares many moons ago.
Was part of a fiitting kit for a mechanical oil gauge.
Other adres you could try is Car Builder Solutions.
Users browsing this forum: No registered users and 357 guests
