Missing Heater Ducting
Postby REPLIC8 » 10 Nov 2013 19:49
Noticed on my car today the heater duct for the passenger side windscreen was not connected beneath the grill on the dashboard. On further inspection I found the entire duct from heater to screen is missing, I assume as this car is totally unmolested that it left the factory without this part being fitted!! So much for the production problems being sorted a Solihull.
Would anybody happen to have the parts I'm missing spare? They are XKC 768 lower demister duct & YKC 573 upper demister duct. I think they're handed parts so need to be for the passenger side. [:)]
1981 TR7 FHC
Postby Maxwell » 10 Nov 2013 20:36
Andy - not sure what the part looks like, but I'm fairly sure I have some black piping around 3-inch diameter that came from the car we broke... Left and right....
Is this what you are looking for?
Maxwell [:)]
2.0 TR7 FHC \ Current
1.8 Mazda MX5 \ Current
Postby dursleyman » 10 Nov 2013 22:31
I have got all of those plastic pipes/ducts from a couple of cars, if you can just identify which bits you want. I am in Gloucestershire.
1980 TR7 Sprint DHC
Reddragon
Postby Reddragon » 11 Nov 2013 10:33
I believe what he is in need of is the left hand side black plactic directional housing that has a retangular base that snaps into the bottom of the heater than directs the air on to the windshield. The part numbers are correct but Rimmers does not have pictures, only lists as upper duct and duct. This unit is usually secured with 2 screws to the dashboard at the base of the windshield. Top is about 10 inches x 2 with slots for the air to come out of.
I have a very old catalog from which I am giving this description.
Hope this helps.
Dale
1974 TR6
1977 TR7 FHC
Postby REPLIC8 » 11 Nov 2013 17:35
Dales description is pretty good. Here is the picture from the parts book I have with the relevant parts highlighted.
Russ, if these are the bits you have I'd be interested.
[img][IMG]http://i473.photobucket.com/albums/rr92/REPLIC8-2008/scanandy1_zps964ced7c.jpg[/img][/img]
1981 TR7 FHC
Postby DNK » 11 Nov 2013 18:42
Do you need 2 & 3 ?
Stick a Wedge In It
Postby dursleyman » 11 Nov 2013 22:33
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by REPLIC8</i>
1981 TR7 FHC
I will have a look on the shelf tomorrow and report back.
1980 TR7 Sprint DHC
Postby TR Tony » 12 Nov 2013 09:45
You should keep it original Andy, exactly as it was built [:D]
I too had Solihull build quality issues with my coupe. Like yours it was totally original & unmolested when I bought it, with 4,500 miles on the clock & had been in storage for 23 years. The first time I drove it at night I noticed that the green lights above the heater/ventilation levers were not working. I eventually got round to removing the cover & found that the light were there & indeed they all worked fine, but the bulbs were just shoved back in the wiring, not clipped into place above the green lenses. Whoever fitted the cover obviously just couldn't be bother to fit the bulb holders in place first! Still, at least I had the parts actually on the car [:)]
Postby dursleyman » 12 Nov 2013 15:08
OK quick rummage on the top shelf and found these bits which I think are the ones you need. Bit dusty but otherwise fine.
They are yours for the price of the postage or you can collect from Dursley. They weigh almost nothing so post should not be too much.
1980 TR7 Sprint DHC
Postby REPLIC8 » 12 Nov 2013 15:56
Thanks Russ, that's fantastic. PM me your address and I'll sort you a cheque for postage & a couple of beers! [:D]
1981 TR7 FHC
Postby dursleyman » 12 Nov 2013 20:36
PM sent
