Fresh air hood / plenum / duct / foam seals.
supercass
Postby supercass » 08 Nov 2013 14:15
I have made up some new foam seals for the side of this item. The originals were glued on. Unfortunately having removed the glue residue and having a memory marginally better than a goldfish I can't remember how the originals fitted. Anyone got a photo of them in the correct position? (Have done a search) Many thanks in anticipation.supercass
Postby DNK » 08 Nov 2013 19:23
I have a PDF of the instructions
Stick a Wedge In It
supercass
Postby supercass » 26 Nov 2013 07:33
Hi Don,
Are you able to share this on the forum, or PM me (once I sort out how to add my email to my profile). Regards, supercass
Postby DNK » 26 Nov 2013 09:27
Somebody else made some up and their is that PDF
Just email me your email
Stick a Wedge In It
Postby FI Spyder » 26 Nov 2013 13:50
I cut out the foam in the shape of the side cut out but a little larger, then slit around the ends so it slide over the metal and is glued in place with contact cement. Before mounting, cut a upside down T in it so the release cable can fit down and move forward and back as necessary and not leave a gaping hole.
Ianftr8
Postby Ianftr8 » 26 Nov 2013 16:25
Any chance of posting some photos or the PDF instructions? In the twenty odd years that I have owned TR7s & my 8 I don't think I have seen these extra seals on the plenum.
Ian
Ian Freeman
1979 TR8 DHC KDU 315V
Triumph Courier
Triumph owner for 32 years
Postby DNK » 26 Nov 2013 16:58
Stick a Wedge In It
Users browsing this forum: No registered users and 278 guests
