Roof replacement
Ianftr8
Roof replacement
Postby Ianftr8 » 02 Oct 2013 09:32
This is a post on behalf of a friend who needs to change the roof on his car - I have had a really good trawl about and cannot find the write up that showed the pictures.
Can anybody point us in the right direction.
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Triumph owner for 31 years
Postby saabfast » 02 Oct 2013 10:46
I worked from scraps of info found on the internet and the 'How to improve your TR7' book but it is pretty vague in places. I think there is now a comprehensive write-up on jclays site?
Saab 9000 2.3 LPT Auto
Ianftr8
Postby Ianftr8 » 02 Oct 2013 12:25
Thanks Alan,
I had a good trawl through - I was really looking for Chunk's ( I think) Rally car build blog, the write up which showed chopping the whole tin top off and replacing it.
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Postby RUDDY » 02 Oct 2013 13:14
The thread below shows the roof being taken off my new shell and being replaced with a non sunroof skin.
It's quite a simple procedure, un pick your donor roof from the internal side so that it leaves an un-holed 'new' old panel, ie drill the spot welds from the rear and avoid puncturing the flange of the roof skin.
Do the reverse on the roof you are removing, drill out the spot welds through the skin but don't puncture the internal rood structure.
Swap over the skins and spot weld back on after cleaning and treating all mating surfaces.
If you don't have access to a spot welder you will have to drill and plug weld, not sure if some of the new bodyshop adhesives would be enough on their own to hold a skin on.
Cheers, Paul
http://www.forum.triumphtr7.com/topic.a ... C_ID=11433
Ianftr8
Postby Ianftr8 » 02 Oct 2013 13:46
That's exactly the posting I was looking for, Thanks Paul. I'm sorry I confused you with Chunk.
Ian Freeman
1979 TR8 DHC
Triumph Courier
Stevie P
Postby Stevie P » 03 Oct 2013 14:43
Thanks Ian and Ruddy
Just what I needed for inspiration to change the roof skin.
Best,
Postby Maxwell » 03 Oct 2013 15:07
TR-Driver \ 2012 Issue 3 [Page 22]
Maxwell [:D]
2.0 TR7 DHC \ Maxwell \ sold
2.0 TR7 FHC \ Robyn \ sold
3.5 TR7 V8 DHC \ Oliver \ sold
2.0 TR7 FHC \ Current
1.8 Mazda MX5 \ Current
Users browsing this forum: No registered users and 142 guests
