Diff spreader
dycecooper
Diff spreader
Postby dycecooper » 29 Sep 2013 14:56
For those who have re-built their rear axle, did you use a diff spreader? I
Is it a must have? Is there a way round it?
Cheers, John
Postby john 215 » 29 Sep 2013 15:12
Hi John,
Rebuilt loads of TR7 ( and SD1's ) and never needed to spread the diff, we had the said tool at work but I never saw it used.
1976 Speke FHC Beauty
Postby DNK » 29 Sep 2013 15:16
I need a pic of such tool...and maybe one in use??
Stick a Wedge In It
dycecooper
Postby dycecooper » 29 Sep 2013 15:43
Hi John,
That's the answer I was hoping for !
dycecooper
Postby dycecooper » 29 Sep 2013 15:44
Stick a Wedge In It
There are pictures of them on eBay [;)]
Postby john 215 » 29 Sep 2013 15:52
Hi Don,
<font color="red">GW1 </font id="red"> in the picture is an example of the sort of tool, does what it says and spreads the casing by a very small amount
http://trf.zeni.net/TR6greenbook/99.php ... =undefined
Steve @ SandS
Postby Steve @ SandS » 29 Sep 2013 18:22
Hi John,
Same here, after 30 years and rebuilding 00's of axle's I have never needed one.I do have the dummy pinion set up though and have only ever used that once :D
Steve @ S&S Preparations
dycecooper
Postby dycecooper » 29 Sep 2013 18:45
That's all good news, as I'm keeping my TR now so it's. Getting treated to a 3:08
Postby Cobber » 30 Sep 2013 01:46
<font size="2"><font face="Comic Sans MS">Here's an example in use:
The jacking screw the the bottom of the pic is turned to spread the diff housing at the two screws at the mid point of the tool. other diffs don't have threaded holes for the spreader tool they just have plain holes, for these diff the screws are replaced with dowl pins.</font id="Comic Sans MS"></font id="size2">
'98 MG-F, 69'Ford F250.
Postby john 215 » 30 Sep 2013 04:41
Hi John,
Were you the winner of this pinion spacer ?
http://www.ebay.co.uk/itm/TRIUMPH-TR7-T ... 504wt_1018
It is poss to reshape the original if not, although never done this myself I have to say
Postby DNK » 30 Sep 2013 11:03
Cobber- Thanks for the pic
Now... what do you do with it
The diff isn't in 2 pieces ...is it?
Stick a Wedge In It
dycecooper
Postby dycecooper » 30 Sep 2013 11:04
I have not got a spacer yet but they are available, I was in touch with a company that said they had them in stock
Postby Cobber » 30 Sep 2013 12:50
<font size="2"><font face="Comic Sans MS">Nah, it's not in two pieces. It forces the two sides of the casing a bit further apart so as to make the removal and refitting of the diff center is easy.
When the pressure is released from the housing by undoing the jacking screw the housing springs back.</font id="Comic Sans MS"></font id="size2">
Users browsing this forum: No registered users and 336 guests
