Speedo cable replacement
g4zur
Postby g4zur » 28 Sep 2013 10:48
Hello All
Could someone please advise on the procedure for replacing the speedo cable.[?]
1980 fhc 2.0l
many thanks as always
Regards
Gareth
G.P.Albrighton
Postby FI Spyder » 28 Sep 2013 13:37
Pretty straight forward. Going from memory. Put car on jack stands. Unscrew cable from back of speedo (this can be done from under the dash without removing dash parts). Might have to remove seat to get under there but that represents an opportunity to put anti-seize on seat bolts (while 7 of my 8 seat bolts were like brand new on Spider, one was rusted in and took days to get out like acid (coke)had been spilled there to start it rusting. I hate to think how other cars are. From under the car, unscrew bolt holding fork that retains cable in the transmission. Pull out cable. When putting new cable, lubricate rubber seal with red rubber grease (found in brake rebuild kits or available separately). Any time I put in rubber seals of any sort I lubricate them so they don't abrade and leak later.
darrellw
Postby darrellw » 28 Sep 2013 14:53
The connection to the speedo under the dash is a clip, there is a tab on the plastic housing that you press and it pulls right out.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby Workshop Help » 28 Sep 2013 16:38
Kind and Gentle Men. Here is the article on speedometer cable servicing.
http://www.forum.triumphtr7.com/topic.a ... eter,cable
Four years? It doesn't seem that long ago.
g4zur
Postby g4zur » 29 Sep 2013 09:37
Once again many thanks for replies. Cable will be replaced and lubed during the week.
Regards
Gareth
G.P.Albrighton
Postby Hasbeen » 29 Sep 2013 11:53
Gareth make sure you have your eyes on, & good light down under the dash, when you want that cable out of the speedo.
I had a hell of a job with mine, the first time. I did not want to put enough pressure on old plastic. Once I'd done it the first time, the next was no problem.
g4zur
Postby g4zur » 29 Sep 2013 18:11
Many thanks Hasbeen for the Tip.
I purchased a small headlight, although new to this I have now been under the dash a few times.
Best regards.
Gareth
G.P.Albrighton
jbsjim
Postby jbsjim » 01 Oct 2013 16:22
Just a note. The upper cable for the speedo (it attaches to a "counter" in the engine bay) comes in 2 lengths. It is a couple inches longer for the fuel injected cars. If anyone knows where I can find the longer FI version I would be obliged to know.
Jim
darrellw
Postby darrellw » 01 Oct 2013 16:34
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jbsjim</i>
I've never ordered from this place, but if you know the length you need they custom build cables:
http://www.vintagebritishcables.com
They have all the correct fittings.
Darrell Walker
Vancouver, WA, USA
jbsjim
Postby jbsjim » 02 Oct 2013 21:26
Thanks for the tip!
g4zur
Postby g4zur » 06 Oct 2013 11:36
Fitted new inner cable this morning, Working fine. decided after reading Mildrid post to first try replacing the Inner, Great thanks Mildrid. Lubed as recommended. All 100%.
Once again thanks to all for help. Great forum great people.
The end of the cable that went into clock was rounded on edges.
Regards
Gareth
G.P.Albrighton
Users browsing this forum: No registered users and 346 guests
